[OpenLayers-Commits] r12392 - sandbox/jsdoc/jsd/OpenLayers/Layer
commits-20090109 at openlayers.org
Sat Sep 17 16:18:56 EDT 2011
Author: mpriour
Date: 2011-09-17 13:18:55 -0700 (Sat, 17 Sep 2011)
New Revision: 12392
sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
Add Grid with autoconverrted doc tags
Modified: sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
--- sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js 2011-09-17 19:57:12 UTC (rev 12391)
+++ sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js 2011-09-17 20:18:55 UTC (rev 12392)
@@ -9,13 +9,20 @@
* @requires OpenLayers/Tile/Image.js
+ * Class: OpenLayers.Layer.WMS
+ * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
+ * Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
+ * constructor.
+ * Inherits from:
+ * @extends OpenLayers.Layer.Grid
OpenLayers.Layer.WMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
- * Hashtable of default parameter key/value pairs
* @const Constant: DEFAULT_PARAMS
- * @type {Object}
- * @memberOf OpenLayers.Layer.WMS.prototype
+ * @type {Object} Hashtable of default parameter key/value pairs
DEFAULT_PARAMS: { service: "WMS",
version: "1.1.1",
@@ -25,80 +32,92 @@
+ * Property: reproject
* *Deprecated*. See http://trac.openlayers.org/wiki/SphericalMercator
* for information on the replacement for this functionality.
- * Try to reproject this layer if its coordinate reference system
+ * @type {boolean} Try to reproject this layer if its coordinate reference system
* is different than that of the base layer. Default is false.
* Set this in the layer options. Should be set to false in
* most cases.
- * @type {boolean}
reproject: false,
- * Default is true for WMS layer.
- * @type {boolean}
+ * APIProperty: isBaseLayer
+ * @type {boolean} Default is true for WMS layer
isBaseLayer: true,
- * Should the BBOX commas be encoded? The WMS spec says 'no',
+ * APIProperty: encodeBBOX
+ * @type {boolean} Should the BBOX commas be encoded? The WMS spec says 'no',
* but some services want it that way. Default false.
- * @type {boolean}
encodeBBOX: false,
- * If true, the image format will not be automagicaly switched
+ * APIProperty: noMagic
+ * @type {boolean} If true, the image format will not be automagicaly switched
* from image/jpeg to image/png or image/gif when using
* TRANSPARENT=TRUE. Also isBaseLayer will not changed by the
- * constructor. Default false.
- * @type {boolean}
+ * constructor. Default false.
noMagic: false,
- * Keys in this object are EPSG codes for which the axis order
+ * Property: yx
+ * @type {Object} Keys in this object are EPSG codes for which the axis order
* is to be reversed (yx instead of xy, LatLon instead of LonLat), with
* true as value. This is only relevant for WMS versions >= 1.3.0.
- * @type {Object}
yx: {'EPSG:4326': true},
- * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
- * Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
- * constructor.
- * <pre>
- * // The code below creates a transparent WMS layer with additional options.
- * var wms = new OpenLayers.Layer.WMS(
- * "NASA Global Mosaic",
- * "http://wms.jpl.nasa.gov/wms.cgi",
- * layers: "modis,global_mosaic",
- * transparent: true
- * opacity: 0.5,
- * singleTile: true
- * </pre>
- * @param {string} name A name for the layer
- * @param {string} url Base url for the WMS
- * (e.g. http://wms.jpl.nasa.gov/wms.cgi)
- * @param {Object} params An object with key/value pairs representing the
- * GetMap query string parameters and parameter values.
- * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer.
- * These options include all properties listed above, plus the ones
- * inherited from superclasses.
- * @constructor OpenLayers.Layer.WMS
- * @extends OpenLayers.Layer.Grid
+ * @constructor Constructor: OpenLayers.Layer.WMS
+ * Create a new WMS layer object
+ * Examples:
+ * The code below creates a simple WMS layer using the image/jpeg format.
+ * (code)
+ * var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
+ * "http://wms.jpl.nasa.gov/wms.cgi",
+ * {layers: "modis,global_mosaic"});
+ * (end)
+ * Note the 3rd argument (params). Properties added to this object will be
+ * added to the WMS GetMap requests used for this layer's tiles. The only
+ * mandatory parameter is "layers". Other common WMS params include
+ * "transparent", "styles" and "format". Note that the "srs" param will
+ * always be ignored. Instead, it will be derived from the baseLayer's or
+ * map's projection.
+ * The code below creates a transparent WMS layer with additional options.
+ * (code)
+ * layers: "modis,global_mosaic",
+ * transparent: true
+ * opacity: 0.5,
+ * singleTile: true
+ * (end)
+ * Note that by default, a WMS layer is configured as baseLayer. Setting
+ * the "transparent" param to true will apply some magic (see <noMagic>).
+ * The default image format changes from image/jpeg to image/png, and the
+ * layer is not configured as baseLayer.
+ * Parameters:
+ * @param {string} name A name for the layer
+ * @param {string} url Base url for the WMS
+ * (e.g. http://wms.jpl.nasa.gov/wms.cgi)
+ * @param {Object} params An object with key/value pairs representing the
+ * GetMap query string parameters and parameter values.
+ * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer.
+ * These options include all properties listed above, plus the ones
+ * inherited from superclasses.
initialize: function(name, url, params, options) {
var newArguments = [];
//uppercase params
@@ -134,8 +153,8 @@
+ * Method: destroy
* Destroy this layer
- * @methodOf OpenLayers.Layer.WMS.prototype
destroy: function() {
// for now, nothing special to do here.
@@ -144,10 +163,11 @@
+ * Method: clone
* Create a clone of this layer
+ * Returns:
* @return {OpenLayers.Layer.WMS} An exact clone of this layer
clone: function (obj) {
@@ -167,11 +187,12 @@
+ * APIMethod: reverseAxisOrder
* Returns true if the axis order is reversed for the WMS version and
* projection of the layer.
+ * Returns:
* @return {boolean} true if the axis order is reversed, false otherwise.
reverseAxisOrder: function() {
return (parseFloat(this.params.VERSION) >= 1.3 &&
@@ -179,15 +200,17 @@
+ * Method: getURL
* Return a GetMap query string for this layer
+ * Parameters:
* @param {OpenLayers.Bounds} bounds A bounds representing the bbox for the
* request.
+ * Returns:
* @return {string} A string with the layer's url and parameters and also the
* passed-in bounds and appropriate tile size specified as
* parameters.
getURL: function (bounds) {
bounds = this.adjustBounds(bounds);
@@ -206,14 +229,15 @@
+ * APIMethod: mergeNewParams
* Catch changeParams and uppercase the new params to be merged in
* before calling changeParams on the super class.
* Once params have been changed, the tiles will be reloaded with
* the new parameters.
+ * Parameters:
* @param {Object} newParams Hashtable of new params to use
mergeNewParams:function(newParams) {
var upperParams = OpenLayers.Util.upperCaseObject(newParams);
@@ -223,17 +247,19 @@
+ * APIMethod: getFullRequestString
* Combine the layer's url with its params and these newParams.
* Add the SRS parameter from projection -- this is probably
* more eloquently done via a setProjection() method, but this
* works for now and always.
+ * Parameters:
* @param {string} altUrl Use this as the url instead of the layer's url
+ * Returns:
* @return {string}
getFullRequestString:function(newParams, altUrl) {
var mapProjection = this.map.getProjectionObject();
More information about the Commits
