[OpenLayers-Commits] r12396 - sandbox/jsdoc/jsd/OpenLayers/Layer
commits-20090109 at openlayers.org
Sat Sep 17 16:49:22 EDT 2011
Author: tschaub
Date: 2011-09-17 13:49:21 -0700 (Sat, 17 Sep 2011)
New Revision: 12396
sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
Doc corrections.
Modified: sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
--- sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js 2011-09-17 20:26:49 UTC (rev 12395)
+++ sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js 2011-09-17 20:49:21 UTC (rev 12396)
@@ -17,8 +17,11 @@
OpenLayers.Layer.WMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
- * @const Constant: DEFAULT_PARAMS
- * @type {Object} Hashtable of default parameter key/value pairs
+ * Hashtable of default parameter key/value pairs.
+ * @const DEFAULT_PARAMS
+ * @type {Object}
+ * @private
+ * @memberOf OpenLayers.Layer.WMS.prototype
DEFAULT_PARAMS: { service: "WMS",
version: "1.1.1",
@@ -28,44 +31,49 @@
- * @type {boolean} Try to reproject this layer if its coordinate reference system
+ * Try to reproject this layer if its coordinate reference system
* is different than that of the base layer. Default is false.
* Set this in the layer options. Should be set to false in
* most cases.
+ * @type {boolean}
* @private
* @deprecated See http://trac.openlayers.org/wiki/SphericalMercator for
* information on the replacement for this functionality.
reproject: false,
- * APIProperty: isBaseLayer
- * @type {boolean} Default is true for WMS layer
+ * Default is true for WMS layer
+ * @type {boolean}
isBaseLayer: true,
- * APIProperty: encodeBBOX
- * @type {boolean} Should the BBOX commas be encoded? The WMS spec says 'no',
+ * Should the BBOX commas be encoded? The WMS spec says 'no',
* but some services want it that way. Default false.
+ * @type {boolean}
encodeBBOX: false,
- * APIProperty: noMagic
- * @type {boolean} If true, the image format will not be automagicaly switched
+ * If true, the image format will not be automagicaly switched
* from image/jpeg to image/png or image/gif when using
* TRANSPARENT=TRUE. Also isBaseLayer will not changed by the
- * constructor. Default false.
+ * constructor. Default false.
+ * @type {boolean}
noMagic: false,
- * Property: yx
- * @type {Object} Keys in this object are EPSG codes for which the axis order
+ * Keys in this object are EPSG codes for which the axis order
* is to be reversed (yx instead of xy, LatLon instead of LonLat), with
* true as value. This is only relevant for WMS versions >= 1.3.0.
+ * @type {Object}
yx: {'EPSG:4326': true},
@@ -133,7 +141,6 @@
- * Method: destroy
* Destroy this layer
@@ -144,10 +151,8 @@
- * Method: clone
* Create a clone of this layer
- * Returns:
* @return {OpenLayers.Layer.WMS} An exact clone of this layer
@@ -169,11 +174,9 @@
- * APIMethod: reverseAxisOrder
* Returns true if the axis order is reversed for the WMS version and
* projection of the layer.
- * Returns:
* @return {boolean} true if the axis order is reversed, false otherwise.
@@ -183,14 +186,11 @@
- * Method: getURL
* Return a GetMap query string for this layer
- * Parameters:
* @param {OpenLayers.Bounds} bounds A bounds representing the bbox for the
* request.
- * Returns:
* @return {string} A string with the layer's url and parameters and also the
* passed-in bounds and appropriate tile size specified as
* parameters.
@@ -214,14 +214,12 @@
- * APIMethod: mergeNewParams
* Catch changeParams and uppercase the new params to be merged in
* before calling changeParams on the super class.
* Once params have been changed, the tiles will be reloaded with
* the new parameters.
- * Parameters:
* @param {Object} newParams Hashtable of new params to use
@@ -233,18 +231,15 @@
- * APIMethod: getFullRequestString
* Combine the layer's url with its params and these newParams.
* Add the SRS parameter from projection -- this is probably
* more eloquently done via a setProjection() method, but this
* works for now and always.
- * Parameters:
* @param {string} altUrl Use this as the url instead of the layer's url
- * Returns:
* @return {string}
More information about the Commits
