[OpenLayers-Commits] r12397 - sandbox/jsdoc/jsd/OpenLayers/Layer
commits-20090109 at openlayers.org
Sat Sep 17 16:53:23 EDT 2011
Author: mpriour
Date: 2011-09-17 13:53:20 -0700 (Sat, 17 Sep 2011)
New Revision: 12397
sandbox/jsdoc/jsd/OpenLayers/Layer/Grid.js
doc changes Grid.js
Modified: sandbox/jsdoc/jsd/OpenLayers/Layer/Grid.js
--- sandbox/jsdoc/jsd/OpenLayers/Layer/Grid.js 2011-09-17 20:49:21 UTC (rev 12396)
+++ sandbox/jsdoc/jsd/OpenLayers/Layer/Grid.js 2011-09-17 20:53:20 UTC (rev 12397)
@@ -10,108 +10,119 @@
- * Class: OpenLayers.Layer.Grid
+ * @namespace OpenLayers.Layer
+ * @class
+ * @classdesc
* Base class for layers that use a lattice of tiles. Create a new grid
* layer with the <OpenLayers.Layer.Grid> constructor.
- * Inherits from:
* @extends OpenLayers.Layer.HTTPRequest
OpenLayers.Layer.Grid = OpenLayers.Class(OpenLayers.Layer.HTTPRequest, {
- * APIProperty: tileSize
+ * @memberOf OpenLayers.Layer.Grid.prototype.prototype
* @type {OpenLayers.Size}
tileSize: null,
- * Property: tileOriginCorner
- * @type {string} If the <tileOrigin> property is not provided, the tile origin
+ * If the <tileOrigin> @memberOf OpenLayers.Layer.Grid.prototype is not provided, the tile origin
* will be derived from the layer's <maxExtent>. The corner of the
- * <maxExtent> used is determined by this property. Acceptable values
+ * <maxExtent> used is determined by this @memberOf OpenLayers.Layer.Grid.prototype. Acceptable values
* are "tl" (top left), "tr" (top right), "bl" (bottom left), and "br"
* (bottom right). Default is "bl".
+ * @type {string}
tileOriginCorner: "bl",
- * APIProperty: tileOrigin
- * @type {OpenLayers.LonLat} Optional origin for aligning the grid of tiles.
+ * Optional origin for aligning the grid of tiles.
* If provided, requests for tiles at all resolutions will be aligned
* with this location (no tiles shall overlap this location). If
* not provided, the grid of tiles will be aligned with the layer's
* <maxExtent>. Default is ``null``.
+ * @type {OpenLayers.LonLat}
tileOrigin: null,
- /** APIProperty: tileOptions
- * @type {Object} optional configuration options for <OpenLayers.Tile> instances
+ * optional configuration options for <OpenLayers.Tile> instances
* created by this Layer, if supported by the tile class.
+ * @type {Object}
tileOptions: null,
- * Property: grid
- * @type {Array.<Array.<OpenLayers.Tile>>} This is an array of rows, each row is
+ * This is an array of rows, each row is
* an array of tiles.
+ * @type {Array.<Array.<OpenLayers.Tile>>}
grid: null,
- * APIProperty: singleTile
- * @type {boolean} Moves the layer into single-tile mode, meaning that one tile
+ * Moves the layer into single-tile mode, meaning that one tile
* will be loaded. The tile's size will be determined by the 'ratio'
- * property. When the tile is dragged such that it does not cover the
+ * @memberOf OpenLayers.Layer.Grid.prototype. When the tile is dragged such that it does not cover the
* entire viewport, it is reloaded.
+ * @type {boolean}
singleTile: false,
- /** APIProperty: ratio
- * @type {number} Used only when in single-tile mode, this specifies the
+ * Used only when in single-tile mode, this specifies the
* ratio of the size of the single tile to the size of the map.
+ * @type {number}
ratio: 1.5,
- * APIProperty: buffer
- * @type {number} Used only when in gridded mode, this specifies the number of
+ * Used only when in gridded mode, this specifies the number of
* extra rows and colums of tiles on each side which will
* surround the minimum grid tiles to cover the map.
* For very slow loading layers, a larger value may increase
* performance somewhat when dragging, but will increase bandwidth
- * use significantly.
+ * use significantly.
+ * @type {number}
buffer: 0,
- * APIProperty: numLoadingTiles
- * @type {number} How many tiles are still loading?
+ * How many tiles are still loading?
+ * @type {number}
numLoadingTiles: 0,
- * APIProperty: tileLoadingDelay
- * @type {number} - Number of milliseconds before we shift and load
+ * Number of milliseconds before we shift and load
* tiles. Default is 100.
+ * @type {number}
tileLoadingDelay: 100,
- * Property: timerId
- * @type {number} - The id of the tileLoadingDelay timer.
+ * The id of the tileLoadingDelay timer.
+ * @type {number}
timerId: null,
- * @constructor Constructor: OpenLayers.Layer.Grid
* Create a new grid layer
- * Parameters:
+ * @constructor OpenLayers.Layer.Grid
* @param {string} name
* @param {string} url
* @param {Object} params
- * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer
+ * @param {Object} options Hashtable of extra options to tag onto the layer
initialize: function(name, url, params, options) {
OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,
@@ -132,10 +143,8 @@
- * Method: removeMap
* Called when the layer is removed from the map.
- * Parameters:
* @param {OpenLayers.Map} map The map.
removeMap: function(map) {
@@ -146,8 +155,8 @@
- * APIMethod: destroy
* Deconstruct the layer and clear the grid.
destroy: function() {
this.clearGrid();
@@ -157,9 +166,9 @@
- * Method: clearGrid
* Go through and remove all tiles from the grid, calling
* destroy() on each of them to kill circular references
clearGrid:function() {
if (this.grid) {
@@ -176,13 +185,9 @@
- * APIMethod: clone
* Create a clone of this layer
- * Parameters:
* @param {Object} obj Is this ever used?
- * Returns:
* @return {OpenLayers.Layer.Grid} An exact clone of this OpenLayers.Layer.Grid
clone: function (obj) {
@@ -209,12 +214,11 @@
- * Method: moveTo
* This function is called whenever the map is moved. All the moving
* of actual 'tiles' is done by the map, but moveTo's role is to accept
* a bounds and make sure the data that that bounds requires is pre-loaded.
- * Parameters:
* @param {OpenLayers.Bounds} bounds
* @param {boolean} zoomChanged
* @param {boolean} dragging
@@ -258,10 +262,8 @@
- * Method: moveByPx
* Move the layer based on pixel vector.
- * Parameters:
* @param {number} dx
* @param {number} dy
@@ -272,8 +274,8 @@
- * Method: scheduleMoveGriddedTiles
* Schedule the move of tiles.
scheduleMoveGriddedTiles: function() {
if (this.timerId != null) {
@@ -286,11 +288,9 @@
- * APIMethod: setTileSize
* Check if we are in singleTile mode and if so, set the size as a ratio
- * of the map size (as specified by the layer's 'ratio' property).
- * Parameters:
+ * of the map size (as specified by the layer's 'ratio' @memberOf OpenLayers.Layer.Grid.prototype).
+ * @memberOf OpenLayers.Layer.Grid.prototype: setTileSize
* @param {OpenLayers.Size} size
setTileSize: function(size) {
@@ -303,11 +303,10 @@
- * Method: getGridBounds
- * Deprecated. This function will be removed in 3.0. Please use
+ * This function will be removed in 3.0. Please use
* getTilesBounds() instead.
- * Returns:
+ * @deprecated.
* @return {OpenLayers.Bounds} A Bounds object representing the bounds of all the
* currently loaded tiles (including those partially or not at all seen
* onscreen)
@@ -320,10 +319,8 @@
- * APIMethod: getTilesBounds
* Return the bounds of the tile grid.
- * Returns:
* onscreen).
@@ -348,9 +345,7 @@
- * Method: initSingleTile
- * Parameters:
initSingleTile: function(bounds) {
@@ -389,16 +384,13 @@
- * Method: calculateGridLayout
* Generate parameters for the grid layout.
- * Parameters:
* @param {OpenLayers.Bound} bounds
* @param {OpenLayers.LonLat} origin
* @param {number} resolution
- * Returns:
- * Object containing properties tilelon, tilelat, tileoffsetlat,
+ * @return {Object} object containing properties tilelon, tilelat, tileoffsetlat,
* tileoffsetlat, tileoffsetx, tileoffsety
calculateGridLayout: function(bounds, origin, resolution) {
@@ -426,14 +418,13 @@
- * Method: getTileOrigin
* Determine the origin for aligning the grid of tiles. If a <tileOrigin>
- * property is supplied, that will be returned. Otherwise, the origin
- * will be derived from the layer's <maxExtent> property. In this case,
+ * is supplied, that will be returned. Otherwise, the origin
+ * will be derived from the layer's <maxExtent>. In this case,
* the tile origin will be the corner of the <maxExtent> given by the
- * <tileOriginCorner> property.
+ * <tileOriginCorner>.
- * Returns:
* @return {OpenLayers.LonLat} The tile origin.
getTileOrigin: function() {
@@ -452,9 +443,7 @@
- * Method: initGriddedTiles
- * Parameters:
initGriddedTiles:function(bounds) {
@@ -545,11 +534,10 @@
- * Method: getMaxExtent
* Get this layer's maximum extent. (Implemented as a getter for
* potential specific implementations in sub-classes.)
- * Returns:
getMaxExtent: function() {
@@ -557,7 +545,6 @@
- * Method: spiralTileLoad
* Starts at the top right corner of the grid and proceeds in a spiral
* towards the center, adding tiles one at a time to the beginning of a
* queue.
@@ -565,6 +552,7 @@
* Once all the grid's tiles have been added to the queue, we go back
* and iterate through the queue (thus reversing the spiral order from
* outside-in to inside-out), calling draw() on each tile.
spiralTileLoad: function() {
var tileQueue = [];
@@ -630,14 +618,12 @@
- * APIMethod: addTile
- * Create a tile, initialize it, and add it to the layer div.
- * Parameters
+ * Create a tile, initialize it, and add it to the layer div.
* bounds - {<OpenLayers.Bounds>}
* position - {<OpenLayers.Pixel>}
- * Returns:
* @return {OpenLayers.Tile} The added OpenLayers.Tile
addTile:function(bounds, position) {
@@ -646,11 +632,9 @@
- * Method: addTileMonitoringHooks
* This function takes a tile as input and adds the appropriate hooks to
* the tile so that the layer can keep track of the loading tiles.
- * Parameters:
* @param {OpenLayers.Tile} tile
addTileMonitoringHooks: function(tile) {
@@ -677,11 +661,9 @@
- * Method: removeTileMonitoringHooks
* This function takes a tile as input and removes the tile hooks
* that were added in addTileMonitoringHooks()
- * Parameters:
removeTileMonitoringHooks: function(tile) {
@@ -695,7 +677,7 @@
- * Method: moveGriddedTiles
+ * @memberOf OpenLayers.Layer.Grid.prototype: moveGriddedTiles
moveGriddedTiles: function() {
var shifted = true;
@@ -724,10 +706,8 @@
- * Method: shiftRow
* Shifty grid work
- * Parameters:
* @param {boolean} prepend if true, prepend to beginning.
* if false, then append to end
@@ -760,10 +740,8 @@
- * Method: shiftColumn
* Shift grid work in the other dimension
- * Parameters:
@@ -794,11 +772,9 @@
- * Method: removeExcessTiles
* When the size of the map or the buffer changes, we may need to
* remove some excess rows and columns.
- * Parameters:
* @param {number} rows Maximum number of rows we want our grid to have.
* @param {number} columns Maximum number of columns we want our grid to have.
@@ -826,9 +802,9 @@
- * Method: onMapResize
* For singleTile layers, this will set a new tile size according to the
* dimensions of the map pane.
+ * @memberOf OpenLayers.Layer.Grid.prototype: onMapResize
onMapResize: function() {
if (this.singleTile) {
@@ -838,13 +814,9 @@
- * APIMethod: getTileBounds
* Returns The tile bounds for a layer given a pixel location.
- * Parameters:
* @param {OpenLayers.Pixel} viewPortPx The location in the viewport.
- * Returns:
* @return {OpenLayers.Bounds} Bounds of the tile at the given pixel location.
getTileBounds: function(viewPortPx) {
More information about the Commits
