[OpenLayers-Commits] r12421 - sandbox/camptocamp/clientzoom/tests/Tile
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Sep 29 10:24:25 EDT 2011
Author: erilem
Date: 2011-09-29 07:24:24 -0700 (Thu, 29 Sep 2011)
New Revision: 12421
   sandbox/camptocamp/clientzoom/tests/Tile/BackBufferable.html
better (and correct) tests to verify that back buffers are created and scaled as appropriate based on the layer scale
Modified: sandbox/camptocamp/clientzoom/tests/Tile/BackBufferable.html
--- sandbox/camptocamp/clientzoom/tests/Tile/BackBufferable.html	2011-09-29 13:21:05 UTC (rev 12420)
+++ sandbox/camptocamp/clientzoom/tests/Tile/BackBufferable.html	2011-09-29 14:24:24 UTC (rev 12421)
@@ -107,81 +107,116 @@
     function test_updateBackBuffer_scaled_layer(t) {
-        t.plan(11);
+        t.plan(16);
-        var resolution, serverSupportedResolution, backBuffer, scale;
+        // set up
-        var map = new OpenLayers.Map('map');
+        var backBuffer;
+        var map = new OpenLayers.Map('map', {
+            resolutions: [32, 16, 8, 4, 2, 1]
+        var serverResolitions = layer.serverResolutions;
+        layer.serverResolutions = [32, 16, 8];
         map.addLayer(layer);
-        map.zoomToMaxExtent();
+        map.setCenter(new OpenLayers.LonLat(0, 0), 2);
         tile = new OpenLayers.Tile.Image(layer, position, bounds, null);
+        tile.backBufferMode = 2; // transition effect
         // mock createBackBuffer to avoid removing the image
         // div from the tile
-        tile.createBackBuffer = function() {
+        tile.insertBackBuffer = function() {
             return this.frame.cloneNode(false);
-        map.getResolution = function() {
-            return resolution;
+        tile.removeBackBuffer = function() {
-        layer.getServerSupportedResolution = function() {
-            return serverSupportedResolution;
+        // test
-        layer.getResolutionScale = function() {
-            return scale;
-        resolution = 32, serverSupportedResolution = 32, scale = 1;
         tile.draw();
         // check initial state
-        t.eq(tile.backBufferData.resolution, 32,
-             '[0] resolution 2 is set in the back buffer data');
+        t.eq(tile.backBufferData.resolution, 8,
+             'resolution 8 is set in the back buffer data');
         tile.isLoading = false;
-        // change to a server-supported resolution
-        resolution = 16, serverSupportedResolution = 16, scale = 1;
+        // change resolution from 8 to 4
+        map.zoomTo(3);
         backBuffer = tile.updateBackBuffer();
+        t.ok(backBuffer == undefined,
+            '[8->4] updateBackBuffer returns undefined');
+        // change resolution from 8 to 2
+        map.zoomTo(2); tile.setBackBufferData(); map.zoomTo(4);
+        backBuffer = tile.updateBackBuffer();
+            '[8->2] updateBackBuffer returns undefined');
+        // change resolution from 16 to 4
+        map.zoomTo(1); tile.setBackBufferData(); map.zoomTo(3);
         t.ok(backBuffer != undefined,
-             '[1] updateBackBuffer returns a back buffer tile');
+             '[16->4] updateBackBuffer returns a back buffer tile');
         t.eq(backBuffer.style.width, '512%',
-             '[1] back buffer width is as expected');
+             '[16->4] back buffer width is as expected');
-             '[1] back buffer height is as expected');
-        tile.resetBackBuffer();
+             '[16->4] back buffer height is as expected');
-        // change to a server-unsupported resolution
-        resolution = 8, serverSupportedResolution = 16, scale = 1;
+        // change resolution from 32 to 1
+        map.zoomTo(0); tile.setBackBufferData(); map.zoomTo(5);
+        t.ok(backBuffer != undefined,
+             '[32->1] updateBackBuffer returns a back buffer tile');
+        t.eq(backBuffer.style.width, '1024%',
+             '[32->1] back buffer width is as expected');
+             '[32->1] back buffer height is as expected');
+        // change resolution from 4 to 2
+        map.zoomTo(3); tile.setBackBufferData(); map.zoomTo(4);
-             '[2] updateBackBuffer returns undefined');
-        t.eq(tile.backBufferData.resolution, 8,
-             '[2] updateBackBuffer correctly sets the back buffer data');
+            '[4->2] updateBackBuffer returns undefined');
-        // change back to a server-supported resolution
-        resolution = 16, serverSupportedResolution = 16, scale = 2;
+        // change resolution from 4 to 1
+        map.zoomTo(3); tile.setBackBufferData(); map.zoomTo(5);
-             '[3] updateBackBuffer returns undefined');
-        t.eq(tile.backBufferData.resolution, 16,
-             '[3] updateBackBuffer correctly sets the back buffer data');
+            '[4->1] updateBackBuffer returns undefined');
+        // change resolution from 1 to 4
+        map.zoomTo(5); tile.setBackBufferData(); map.zoomTo(3);
+             '[1->4] updateBackBuffer returns undefined');
+        // change resolution from 4 to 8
+        map.zoomTo(3); tile.setBackBufferData(); map.zoomTo(2);
+             '[4->8] updateBackBuffer returns undefined');
+        // change resolution from 4 to 16
+        map.zoomTo(3); tile.setBackBufferData(); map.zoomTo(1);
-             '[3] updateBackBuffer returns a back buffer tile');
+             '[4->16] updateBackBuffer returns a back buffer tile');
         t.eq(backBuffer.style.width, '128%',
-             '[3] back buffer width is as expected');
+             '[4->16] back buffer width is as expected');
-             '[3] back buffer height is as expected');
+             '[4->16] back buffer height is as expected');
-        delete layer.getServerSupportedResolution;
+        // tear down
         map.removeLayer(layer);
         map.destroy();
More information about the Commits mailing list
