[OpenLayers-Commits] r12422 - in sandbox/camptocamp/clientzoom: lib/OpenLayers/Layer lib/OpenLayers/Tile tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Sep 29 10:31:24 EDT 2011
Author: erilem
Date: 2011-09-29 07:31:23 -0700 (Thu, 29 Sep 2011)
New Revision: 12422
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TMS.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TileCache.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/BackBufferable.js
   sandbox/camptocamp/clientzoom/tests/Layer/Grid.html
function getServerSupportedResolution renamed to getServerResolution
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js	2011-09-29 14:31:23 UTC (rev 12422)
@@ -261,14 +261,14 @@
                               !tilesBounds.containsBounds(bounds, true);
                 var resolution = this.map.getResolution();
-                var supportedResolution =
-                    this.getServerSupportedResolution(resolution);
+                var serverResolution =
+                    this.getServerResolution(resolution);
-                if(resolution !== supportedResolution) {
-                    bounds = this.map.calculateBounds(null, supportedResolution);
+                if(resolution !== serverResolution) {
+                    bounds = this.map.calculateBounds(null, serverResolution);
                     if(forceReTile) {
                         // stretch the layer div
-                        var scale = supportedResolution / resolution;
+                        var scale = serverResolution / resolution;
                         this.transformDiv(scale);
                 } else {
@@ -290,7 +290,7 @@
-     * Method: getServerSupportedResolution
+     * Method: getServerResolution
      * Return the server-supported resolution that is the closest to
      *     the resolution passed as a parameter. If no resolution is
      *     passed the map resolution is used.
@@ -301,7 +301,7 @@
      * Returns:
      * {Number} The closest server supported resolution.
-    getServerSupportedResolution: function(resolution) {
+    getServerResolution: function(resolution) {
         resolution = resolution || this.map.getResolution();
         if(this.serverResolutions &&
            OpenLayers.Util.indexOf(this.serverResolutions, resolution) === -1) {
@@ -329,7 +329,7 @@
      * {Number} The closest server supported zoom.
     getServerSupportedZoom: function() {
-        return this.map.getZoomForResolution(this.getServerSupportedResolution());
+        return this.map.getZoomForResolution(this.getServerResolution());
@@ -583,7 +583,7 @@
                       Math.max(1, 2 * this.buffer);
         var origin = this.getTileOrigin();
-        var resolution = this.getServerSupportedResolution();
+        var resolution = this.getServerResolution();
         var tileLayout = this.calculateGridLayout(bounds, origin, resolution);
@@ -858,7 +858,7 @@
         var grid = this.grid;
         var modelRow = grid[modelRowIndex];
         var deltaY = (prepend) ? -this.tileSize.h : this.tileSize.h;
         var deltaLat = resolution * -deltaY;
@@ -891,7 +891,7 @@
     shiftColumn: function(prepend) {
         var deltaX = (prepend) ? -this.tileSize.w : this.tileSize.w;
         var deltaLon = resolution * deltaX;
         for (var i=0, len=this.grid.length; i<len; i++) {
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TMS.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TMS.js	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TMS.js	2011-09-29 14:31:23 UTC (rev 12422)
@@ -171,7 +171,7 @@
     getURL: function (bounds) {
         bounds = this.adjustBounds(bounds);
-        var res = this.getServerSupportedResolution();
+        var res = this.getServerResolution();
         var x = Math.round((bounds.left - this.tileOrigin.lon) / (res * this.tileSize.w));
         var y = Math.round((bounds.bottom - this.tileOrigin.lat) / (res * this.tileSize.h));
         var z = this.serverResolutions != null ?
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TileCache.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TileCache.js	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/TileCache.js	2011-09-29 14:31:23 UTC (rev 12422)
@@ -109,7 +109,7 @@
      *     passed-in bounds and appropriate tile size specified as parameters.
     getURL: function(bounds) {
         var bbox = this.maxExtent;
         var size = this.tileSize;
         var tileX = Math.round((bounds.left - bbox.left) / (res * size.w));
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js	2011-09-29 14:31:23 UTC (rev 12422)
@@ -332,7 +332,7 @@
     getIdentifier: function() {
         return this.serverResolutions != null ?
-                                    this.getServerSupportedResolution()) :
+                                    this.getServerResolution()) :
             this.getServerSupportedZoom() + this.zoomOffset;
@@ -351,7 +351,7 @@
                 var denom =
                     OpenLayers.METERS_PER_INCH *
                     OpenLayers.INCHES_PER_UNIT[this.units] *
-                    this.getServerSupportedResolution() / 0.28E-3;
+                    this.getServerResolution() / 0.28E-3;
                 var diff = Number.POSITIVE_INFINITY;
                 var delta;
                 for (var i=0, ii=this.matrixIds.length; i<ii; ++i) {
@@ -383,7 +383,7 @@
      *     (respectively) of the given location within the target tile.
     getTileInfo: function(loc) {
         var fx = (loc.lon - this.tileOrigin.lon) / (res * this.tileSize.w);
         var fy = (this.tileOrigin.lat - loc.lat) / (res * this.tileSize.h);
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js	2011-09-29 14:31:23 UTC (rev 12422)
@@ -148,7 +148,7 @@
      * {Object} - an object with x, y and z properties.
     getXYZ: function(bounds) {
         var x = Math.round((bounds.left - this.maxExtent.left) /
         var y = Math.round((this.maxExtent.top - bounds.top) /
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/BackBufferable.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/BackBufferable.js	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/BackBufferable.js	2011-09-29 14:31:23 UTC (rev 12422)
@@ -102,8 +102,8 @@
         var layer = this.layer,
             map = layer.map,
             mapResolution = map.getResolution();
-        return layer.getServerSupportedResolution ?
-                   layer.getServerSupportedResolution(mapResolution) :
+        return layer.getServerResolution ?
+                   layer.getServerResolution(mapResolution) :
                    mapResolution;
Modified: sandbox/camptocamp/clientzoom/tests/Layer/Grid.html
--- sandbox/camptocamp/clientzoom/tests/Layer/Grid.html	2011-09-29 14:24:24 UTC (rev 12421)
+++ sandbox/camptocamp/clientzoom/tests/Layer/Grid.html	2011-09-29 14:31:23 UTC (rev 12422)
@@ -624,32 +624,32 @@
         t.eq( layer.tileSize, null, "layer.tileSize is null after destroy" );
-    function test_getServerSupportedResolution(t) {
+    function test_getServerResolution(t) {
         t.plan(4);
         var layer = new OpenLayers.Layer.Grid('', '', {}, {});
         var res;
-        res = layer.getServerSupportedResolution(1);
-        t.eq(res, 1, '[1] getServerSupportedResolution return value is correct');
+        res = layer.getServerResolution(1);
+        t.eq(res, 1, '[1] getServerResolution return value is correct');
         layer.serverResolutions = [2, 1];
-        t.eq(res, 1, '[2] getServerSupportedResolution return value is correct');
+        t.eq(res, 1, '[2] getServerResolution return value is correct');
         layer.serverResolutions = [2];
-        t.eq(res, 2, '[3] getServerSupportedResolution return value is correct');
+        t.eq(res, 2, '[3] getServerResolution return value is correct');
         var exc;
         layer.serverResolutions = [0.5];
         try {
         } catch(e) {
             exc = e;
-        t.ok(exc != undefined, '[4] getServerSupportedResolution generates exception');
+        t.ok(exc != undefined, '[4] getServerResolution generates exception');
     function test_getServerSupportedZoom(t) {
More information about the Commits mailing list
