[OpenLayers-Dev] Vector rendering status
Pierre GIRAUD
bluecarto at gmail.com
Tue Nov 14 12:07:20 EST 2006
I just commited some modifications that have effects on several files.
It concerns the refactoring to get geometry as a feature property.
The Geometry class doesn't depend on Feature any more and attributes
related methods were moved to the Feature class.
To build a feature, one now needs to write something like :
var point = new OpenLayers.Geometry.Point(10,10);
var feature = new OpenLayers.Feature();
feature.setGeometry(point); // this would also be done in the Feature
constructor
layer.addFeatures(feature);
Almost everything is still working, but the following functionnalities ain't :
- the markers related methods in the feature class won't work (if they did),
- the selection tool (in editing) is slightly broken, but Bertil and
I will pay attention to this.
Hope, this was a good choice.
Regards
Pierre
On 11/14/06, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> I'm about to continue your work on GML. What is the best way. Do I try
> to implement the handles for other geometries ? Or do you want me to
> have a look at the mapBuilder GML parser (using xpath) and try to
> reuse it in OL ?
> Regards
> Pierre
> On 11/14/06, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> > Status after the Australian shift:
> > 1. I've renamed examples/wfs_features.html to examples/GML.html
> > 2. I've created a Layer/GML.js class (used by the GML.html class). This
> > is based on the previous code in the example.
> > 3. We can raise any issues with the Vector branch in Trac now. Chris has
> > created a milestone = "Vector RC1" which we can use to assign to our issues.
> > 4. Raised ticked #395 "Remove dependancy upon Prototype.js"
> > http://trac.openlayers.org/ticket/395#preview
> > 5. For those interested in Mapbuilder, I've updated MapPaneOL so that it
> > loads a GML file defined in the Context into an OpenLayers Layer/Gml object.
> > 6. I've created an examples/GMLTasmania.html which contains a sample of
> > GML2 lines, polygons, and points. At the moment, only some of the lines
> > are displayed. Our parser needs to process all feature types.
> > I'm about to have dinner soon, but will be back on later tonight - in
> > 2hrs or so.
> > Cameron Shorter
> > http://cameron.shorter.net
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
More information about the Dev
