[OpenLayers-Dev] WMS should default to GIF instead of JPG
Cameron Shorter
cameron.shorter at gmail.com
Tue Nov 21 23:16:21 EST 2006
Chris suggested I raise the issue on this list. I've taking the liberty
of tracking it as well:
http://trac.openlayers.org/ticket/423#preview
Currently, the image format that a WMS defaults to is JPG. JPG is best
used to display photos and the like which contains millions of colors.
It compresses well, however it is lossy and doesn't allow transparency.
It is a good format for a aerial photo basemaps.
For WMS layers, which are usually placed over a photo basemap like
GoogleMaps?, GIF is a better format. GIF is lossless and works best for
images with a fixed number of colors (as is usually returned by WMS
layers). GIF allows transparency.
And for the record, PNG has similar properties to GIF, but older
versions of IE have problems rendering PNG layers, so is not a suggested
format.
So I suggest that the default format offered by the Openlayers WMS is
GIF format instead of JPG as is currently the case.
Cameron Shorter
http://cameron.shorter.net
More information about the Dev
