[OpenLayers-Dev] PanZoomSlide control: panning with a slide
Erik Uzureau
euzuro at gmail.com
Thu Nov 30 04:46:19 EST 2006
Hi Duarte,
I guess the email I just sent a few moments ago was a little too late
--- sorry, but i am very behind on reading project email. We would
certainly be interested in seeing what you have come up with for this
slide control :-)
The easiest way to show us the feature is to send a link to running code.
If that's not possible, then you can follow the standard procedure for
contributing code to the OL project [1]. Basically, make a ticket in
the OL TRAC and attach your file as a patch.
As it turns out, there is already a ticket opened for this problem, so
you can just attach your patch to ticket 110 [2]
To be able to include your patch in the code base, we would need you
to fill out a Contributors License Agreement, either individual or
through your company. The whole progress and all the links can be
found on the HowToContribute wiki[1] from the openlayers.org website.
Hope to see that patch!!
Erik
[1] http://trac.openlayers.org/wiki/HowToContribute
[2] http://trac.openlayers.org/ticket/110
On 11/30/06, Duarte Carreira <DCarreira at edia.pt> wrote:
> I would like to contribute with this control. It's a modified PanZoom
> control that just pans sliding the map smoothly instead of in a single step.
> I called it PanZoomSlide.
> To do the animation I used the example in www.hesido.com, and the 2 small
> original functions that I used remain with his identification in the header.
> He encourages others to use his examples but there is no mention of license
> type. Anyway there are hundreds of variations of the same simple slide
> effect. So if there's a problem (which I don't think there is) it is always
> possible to use something else - even rico in a manner similar to corner.js.
> Or even reinvent the wheel...
> Anyway PanZoomSlide.js is only 6.84Kb. Original PanZoom.js is 4.5Kb.
> To use:
> - include PanZoomSlide.js after OpenLayers.js
> - create a PanZoomSlide control just like you would a PanZoom:
> map.addControl(new OpenLayers.Control.PanZoomSlide());
> That's it.
> I'm not sure if OpenLayer team finds this worthwhile. If it is tell me how
> to send the file.
> Regards,
> Duarte
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
