[OpenLayers-Dev] [Fwd: Images - Alignment Issues]
Erik Uzureau
euzuro at gmail.com
Thu Oct 19 00:40:36 EDT 2006
Just fyi, this problem has been fixed in trunk as documented in
http://trac.openlayers.org/ticket/196
Now if you have a WMS layer that you want to put on top of a
google base layer, you just need to make sure that the wms
layer's 'reproject' property is set to true (this is the case by
default now)
This will be a feature of the soon to arrive 2.2 release
Erik
On 10/4/06, Erik Uzureau <euzuro at gmail.com> wrote:
> Hi Cameron,
> This is a problem that we have been meaning to fix for a while. The
> ticket is here:
> For the time being, if you use the Untiled/WMS, you will get a nicer result.
> --Erik
> On 10/4/06, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> > Attached should be images showing alignment problems using Google
> > Maps/WMS with OpenLayers 2.0rc4.
> > We are using SRS=EPSG:4326 for the WMS. Any suggestions for improvement?
> > Cameron Shorter
> > http://cameron.shorter.net
> > ---------- Forwarded message ----------
> > From: bwelde at neomatix.ca
> > To: Cameron Shorter <cameron.shorter at gmail.com>
> > Date: Tue, 03 Oct 2006 08:52:42 -0400
> > Subject: Images - Alignment Issues
> > Cameron,
> > I've attached two jpg's. Untitled.jpg is Google and our contours.
> > Untitled1.jpg is Terraserver and contours. If we can get the Google
> > data to line up we'll be good. I think I would like to make the Google
> > map data the default instead of Openlayers as well.
> > Thanks
> > Brian
> > This message was sent using IMP, the Internet Messaging Program.
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
More information about the Dev
