[OpenLayers-Dev] [Dev] Re: Vectors in OpenLayers?
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Oct 19 03:44:12 EDT 2006
Will there also be an option to serialize the objects as GML?
Since interaction will mostly be against OGC Web Services.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Paul Spencer <pspencer at dmsolutions.ca>
Naar: Pierre GIRAUD <bluecarto at gmail.com>
Cc: dev at openlayers.org
Onderwerp: Re: [OpenLayers-Dev] [Dev]  Re: Vectors in OpenLayers?
Datum: 19/10/06 00:09
> Hi Pierre,
> I haven't looked at the code but I think that this will be needed in
> some sort of factory object that can create Geometry (and associated
> Shape) objects from WKT.  We are a bit early for implementation
> details right now (despite the fact that I've already done a bunch of
> implementation), but when the design is finalized, we'll need this
> piece.
> This reminds me that Geometry objects need to be able to serialize
> themselves as WKT.
> Cheers
> Paul
> On 13-Oct-06, at 12:46 PM, Pierre GIRAUD wrote:
> &gt; I wanna propose you some peace of code for this.
> &gt; Hope you'll be able to have a quick look and check if I'm the good
> &gt; way.
> &gt;
> &gt; I tried to follow the &quot;factory&quot; pattern, but I'm not sure I
> &gt; implemented it right considering the rest of the architecture.
> &gt;
> &gt; Regards and nice week-end
> &gt;
> &gt; Pierre
> &gt;
> &gt; ps : this code might be useable in the current vector sandbox
> &gt;
> &gt; On 10/13/06, Pierre GIRAUD &lt;bluecarto at gmail.com&gt; wrote:
> &gt;&gt; I don't know if this is a needed functionnality, but it can
probably
> &gt;&gt; help. I was trying to think about and implement a way to add a
> &gt;&gt; feature
> &gt;&gt; by its WKT string writing.
> &gt;&gt;
> &gt;&gt; Something like :
> &gt;&gt;
> &gt;&gt; OpenLayers.Vector.WKT
> &gt;&gt;
> &gt;&gt; p4 = new OpenLayers.Vector.WKT('POINT(-40 30)');
> &gt;&gt;
> &gt;&gt; Regards
> &gt;&gt;
> &gt;&gt; Pierre
> &gt;&gt;
> &gt;&gt; On 10/13/06, Paul Spencer &lt;pspencer at dmsolutions.ca&gt; wrote:
> &gt;&gt; &gt; Thanks Chris :)
> &gt;&gt; &gt;
> &gt;&gt; &gt; Performance really sucks if you add a lot of features.  I
wrote a
> &gt;&gt; &gt; quick loop to add a 1 degree box every 10 degrees and
brought my
> &gt;&gt; &gt; firefox to a halt.  Profiling reveals a number of
problematic
> &gt;&gt; areas,
> &gt;&gt; &gt; the biggest of which is getPx (of course).
> &gt;&gt; &gt;
> &gt;&gt; &gt; I've done some optimization that improves performance in
this case:
> &gt;&gt; &gt;
> &gt;&gt; &gt; * remove the call to Pixel.add(x,y) and directly modify the
pixel
> &gt;&gt; &gt; position - this was a big savings ...
> &gt;&gt; &gt;
> &gt;&gt; &gt; * cached px location in the Point object based on the bounds
of the
> &gt;&gt; &gt; containing vectorLayer so getPx is only called when the
bounds have
> &gt;&gt; &gt; actually changed.
> &gt;&gt; &gt;
> &gt;&gt; &gt; attached is a patch against the sandbox to incorporate these
> &gt;&gt; changes.
> &gt;&gt; &gt;
> &gt;&gt; &gt; Next steps for me are:
> &gt;&gt; &gt;
> &gt;&gt; &gt; * fix rendering in IE and Safari (that was the whole point
of using
> &gt;&gt; &gt; excanvas)
> &gt;&gt; &gt;
> &gt;&gt; &gt; * further optimizations, including:
> &gt;&gt; &gt;
> &gt;&gt; &gt;    o try caching the bounds of each vector and test for
> &gt;&gt; intersection
> &gt;&gt; &gt; with layer bounds before rendering
> &gt;&gt; &gt;
> &gt;&gt; &gt;    o tighten inner loops and remove deep call chains
(possibly
> &gt;&gt; &gt; putting some of the pixel conversion stuff right into
convertToPx)
> &gt;&gt; &gt;
> &gt;&gt; &gt;   o anything else you can think of
> &gt;&gt; &gt;
> &gt;&gt; &gt; * convenience functions for constructing polygons and lines
from
> &gt;&gt; &gt; points without having to construct intermediate objects
> &gt;&gt; &gt;
> &gt;&gt; &gt; Other things that need to be done at some point, but not
> &gt;&gt; necessarily
> &gt;&gt; &gt; for 2.3:
> &gt;&gt; &gt;
> &gt;&gt; &gt; * refactor the code (what, already?) so that the Vector
> &gt;&gt; architecture
> &gt;&gt; &gt; can support multiple rendering types (Canvas, SVG, VML,
possibly
> &gt;&gt; &gt; others in the future) by introducing Layer.Vector subclasses
and a
> &gt;&gt; &gt; new Rendering class that knows how to render into the
sub-classed
> &gt;&gt; &gt; layer types
> &gt;&gt; &gt;
> &gt;&gt; &gt; * refactor styling support to make it less specific to
Canvas
> &gt;&gt; &gt; rendering stuff
> &gt;&gt; &gt;
> &gt;&gt; &gt; * add some Controls for digitizing and possibly editing
> &gt;&gt; &gt;
> &gt;&gt; &gt; Cheers
> &gt;&gt; &gt;
> &gt;&gt; &gt; Paul
> &gt;&gt; &gt;
> &gt;&gt; &gt; On 12-Oct-06, at 7:55 PM, Christopher Schmidt wrote:
> &gt;&gt; &gt;
> &gt;&gt; &gt; &gt; On Thu, Oct 12, 2006 at 05:02:00PM -0400, Paul Spencer
wrote:
> &gt;&gt; &gt; &gt;&gt; Schuyler, et al
> &gt;&gt; &gt; &gt;&gt; attached is a first cut at the vector stuff.  It
extracts
> &gt;&gt; over an
> &gt;&gt; &gt; &gt;&gt; existing openlayers folder and contains only the
new files
> &gt;&gt; I've added
> &gt;&gt; &gt; &gt;&gt; plus a change to OpenLayers.js to load the extra
files by
> &gt;&gt; default
> &gt;&gt; &gt; &gt;&gt; (except for excanvas for some reason ;)).
> &gt;&gt; &gt; &gt;&gt; There is a vector.html in the examples folder.
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt; This code, with some improvements from Schuyler and I,
is now
> &gt;&gt; in place
> &gt;&gt; &gt; &gt; in a sandbox in the OpenLayers SVN. You can check out
with:
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt; svn co http://svn.openlayers.org/sandbox/sderle/vector/
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt; You can try it out at:
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt;
http://openlayers.org/~crschmidt/vector/examples/vector.html
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt; Click once to start drawing a line -- click again to
end it.
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt; FF only at the moment.
> &gt;&gt; &gt; &gt;
> &gt;&gt; &gt; &gt; Cool stuff, Paul, thanks for getting the ball rolling
on this.
> &gt;&gt; &gt; &gt; --
> &gt;&gt; &gt; &gt; Christopher Schmidt
> &gt;&gt; &gt; &gt; Web Developer
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt; |Paul Spencer
pspencer at dmsolutions.ca    |
> &gt;&gt; &gt;
> &gt;&gt; &gt; |Chief Technology Officer
> &gt;&gt; &gt; |DM Solutions Group Inc
http://www.dmsolutions.ca/ |
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt; _______________________________________________
> &gt;&gt; &gt; Dev mailing list
> &gt;&gt; &gt; Dev at openlayers.org
> &gt;&gt; &gt; http://openlayers.org/mailman/listinfo/dev
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt; &gt;
> &gt;&gt;
> &gt;&gt; &lt;wkt.html&gt;
> &gt;&gt; &lt;WKT.js&gt;
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> Dev mailing list
More information about the Dev mailing list
