[OpenLayers-Dev] ANN: OpenLayers 2.2 release candidate 1
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Oct 20 15:48:42 EDT 2006
Hey Schuyler,
I just tried the 2.2RC1, is WMS Untiled still working? I don't get any
map anymore.
It seems OpenLayers is now requesting images larger than 2048 pixels.
Which is over Mapserver's maximum.
Access log:
/cgi-bin/mapserv.exe?map=/lausanne/mapserver/provinces_of_holland.map&LAYERS=nl-prov&FORMAT=image/png&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:28992&BBOX=-66233.766234,341396.103896,234740.25974,491396.103896&WIDTH=2472&HEIGHT=1232
HTTP/1.1" 200 800
If I switch back to 2.1 I get:
/cgi-bin/mapserv.exe?map=/lausanne/mapserver/provinces_of_holland.map&LAYERS=nl-prov&FORMAT=image/png&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:28992&BBOX=-166382.252559727,300000,466382.252559727,600000&WIDTH=1236&HEIGHT=586
HTTP/1.1" 200 12231
so apparently OpenLayers now requests images by default twice as big?
I have opened up a ticket, but the code did not format well in Trac, so
I'll paste it in this e-mail as well.
http://trac.openlayers.org/ticket/364#preview
function mapinit(){
map = new OpenLayers.Map( $('map'), { 'projection': 'EPSG:4326', 'units':'degrees', 'maxExtent': new OpenLayers.Bounds(-180, -90, 180, 90) , 'maxResolution':'auto'}); var layer = new OpenLayers.Layer.WMS.Untiled( "WorldGen",
"http://www2.dmsolutions.ca/cgi-bin/mswms_world?", {layers: 'WorldGen', 'format':'image/png', 'transparent':'true'} );
layer.isBaseLayer = true;
map.addLayers([layer]); var layer = new OpenLayers.Layer.WMS.Untiled( "World Political",
"http://www2.dmsolutions.ca/cgi-bin/mswms_world?", {layers: 'WorldPolitical', 'format':'image/png', 'transparent':'true'} );
layer.isBaseLayer = false;
map.addLayers([layer]); var layer = new OpenLayers.Layer.WMS.Untiled( "WorldGen_Outline",
"http://www2.dmsolutions.ca/cgi-bin/mswms_world?", {layers: 'WorldGen_Outline', 'format':'image/png', 'transparent':'true'} );
map.addLayers([layer]); var layer = new OpenLayers.Layer.WMS.Untiled( "WorldRoads",
"http://www2.dmsolutions.ca/cgi-bin/mswms_world?", {layers: 'WorldRoads', 'format':'image/png', 'transparent':'true'} );
map.addLayers([layer]); var layer = new OpenLayers.Layer.WMS.Untiled( "WorldPlaces",
"http://www2.dmsolutions.ca/cgi-bin/mswms_world?", {layers: 'WorldPlaces', 'format':'image/png', 'transparent':'true'} );
map.addLayers([layer]); var layer = new OpenLayers.Layer.WMS.Untiled( "WorldPOI",
"http://www2.dmsolutions.ca/cgi-bin/mswms_world?", {layers: 'WorldPOI', 'format':'image/png', 'transparent':'true'} );
map.addLayers([layer]); map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToMaxExtent();
Best regards,
Bart
Schuyler Erle schreef:
> The OpenLayers Development Team is proud to announce release candidate
> 1 of OpenLayers 2.2. While the public API maintains backwards
> compatibility with previous 2.x releases, OpenLayers 2.2-rc1
> introduces a number of internal changes that are important for
> developers working inside the OpenLayers library.
> New Features include:
> * Overview Map Control (Thanks Tim Schaub!)
> * Mouse Position Control (Thanks Jeff Dege!)
> * GeoRSS Atom support (Thanks Sean Gilles!)
> * MapServer CGI Layer (Thanks Arnd Wipperman!)
> * Support for displaying WMS on top of Google Maps
> Other changes include:
> * Refactoring the use of Prototype.js. Rather than using
> Prototype.js, OpenLayers has integrated the important pieces of
> the Prototype framework into OpenLayers, and removed offending
> functions like Object.extend(). This means that there should no
> longer be conflicts between OpenLayers and different versions of
> Prototype, or any other Javascript framework.
> * Adding support for a 'lite' build of OpenLayers via 'build
> profiles', as described at http://trac.openlayers.org/wiki/Profiles
> * Addition of a framework for customizing OpenLayers via CSS, e.g.
> Popups. (Not all aspects of the interface are customizable yet,
> e.g. pan/zoom chrome.)
> * A number of other bug fixes, as described in the 2.2 release notes,
> at http://trac.openlayers.org/wiki/ReleaseNotes2.2
> To test 2.2-rc1 in your applications, include the following tag in
> your OpenLayers-powered page:
> <script src="http://openlayers.org/api/2.2-rc1/OpenLayers.js"></script>
> Bug reports can be filed in Trac, under the 2.2 version and milestone.
> We look forward to your feedback. Thanks very much for using
> OpenLayers!
> SDE
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
