[OpenLayers-Dev] OpenLayers + MapServer + Postgis <problem>
E.Stefanakis eipd at otenet.gr
Sun Apr 1 17:32:08 EDT 2007
Hi!
I have two layers defined as follows...
var mslayer1 = new OpenLayers.Layer.WMS( "SHAPEFILE LAYER",
    "http://83.212.51.160/cgi-bin/mapserv.exe?map=/ms4w/apps/emmanuel/htdocs/grdata_nomoi_wgs84.map", {'layers': 'NOMOI' , 'format':'image/png'});
var mslayer2 = new OpenLayers.Layer.WMS( "POSTGIS LAYER",
    "http://83.212.51.160/cgi-bin/mapserv.exe?map=/ms4w/apps/emmanuel/htdocs/grdata_nomoi_wgs84.map", {'layers': 'MATHITES' , 'format':'image/png'});
and the following map file:
MAP
  IMAGETYPE      png
  EXTENT         19.341085 34.809638 29.577942 41.757412
  SIZE           500 500
  SHAPEPATH      "c:/emmanuel/grdata"
  IMAGECOLOR     255 255 255
  UNITS DD
PROJECTION
   "init=epsg:4326"
  END
SYMBOL
   NAME "Circle"
   FILLED true
   TYPE ellipse
   POINTS 1 1 END
END
  # LAYER SHAPEFILE ---------
  LAYER
    NAME         NOMOI
    DATA         NOMOI_wgs84
    STATUS       OFF
    TYPE         POLYGON
    CLASS
      NAME       "The Greek Prefectures"
      STYLE
        COLOR        200 200 200
        OUTLINECOLOR 32 32 32
      END
    END
  END #
END #
# Layer POSTGIS -----------
 LAYER # Mathites in PostGIS
   NAME         MATHITES
   STATUS ON
   TYPE POINT
   CONNECTIONTYPE POSTGIS
   CONNECTION "dbname=postgis host=localhost
                              user=postgres password=postgres port=5432"
   DATA "the_geom from (select the_geom from mathites_wgs84 where id <10)"
    CLASS
       NAME       "Mathites"
       STYLE
          SYMBOL "Circle"
          SIZE 3
          COLOR        0 0 200
       END
    END
    PROJECTION
      "init=epsg:4326"
    END
 END
#End of Layer ---------------
END
The SHAPEFILE layer works fine! Howver I cannot see the POSTGIS layer...
I get an error message "declare mycursor binary cursor..."
Any suggestion would be greatly appreciated !
Emmanuel.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070402/78fb5451/attachment.html
More information about the Dev mailing list
