[OpenLayers-Dev] show new features (dynamically added) in vector layer
Christine Spietz spietz at fh-bingen.de
Fri Apr 27 11:19:18 EDT 2007
I have problems to show features which are dynamically added to a
vector-layer.
I first initialize my map with a baselayer and some overlays. One of the
overlays is a vector-layer which has some polygon-feature inside.
-----------------------------------snip>----------------------------------
layer_1 = new OpenLayers.Layer.Vector("layer_1");
//init the layer with
var polygonFeature = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Polygon([linearRing]));
layer.addFeatures([polygonFeature]);
//add the layer to the map
map.addLayer(layer_1);
----------------------------------->snip----------------------------------
This works fine. Now I insert another feature in the layer for example after
a button ist clicked:
polygonFeature = new OpenLayers.Feature.Vector(geometry);
polygonFeature .setFid(fid);
layer_1.addFeatures([polygonFeature]);
layer.features.length gives the correct length of the feature-array in
layer_1 and the geometry-object is a correct polygon. So everything seems to
be fine
Now I try to redraw the layer to show all polygon-features included in the
layer. I tried several ways but none of them worked.
-----------------------------------snip>v1-------------------------------
layer_1.redrawFeature(fid,'default');
-----------------------------------snip>v2-------------------------------
map.removeLayer(layer_1,false);
//draw the layer
-----------------------------------snip>v3-------------------------------
drawControls = {
    polygon: new
OpenLayers.Control.DrawFeature(layer_1,OpenLayers.Handler.Polygon)
for(var key in drawControls) {
    map.addControl(drawControls[key]);
I'm using openlayers2.4 rc1 with mozilla firefox 2.0.0.3.
Can anybody please give ma a hint?
Sincerely
Christine
More information about the Dev mailing list
