[OpenLayers-Dev] Documentation sources and versions
Cameron Shorter cameron.shorter at gmail.com
Fri Apr 27 16:13:28 EDT 2007
Looking around at the documentation I've found 3 locations for it.
http://openlayers.org/doc/reference.html
This seems to be run against 2.3?
Where is the source for this documentation? Is it in SVN? Can I find the
2.4rc2 version somewhere?
http://dev.openlayers.org/docs/index.html
I assume this is run against 2.4rc2?
http://trac.openlayers.org/wiki/Documentation
Is this still being maintained?
Recommendation 1:
* Put version number with documentation.
Recommendation 2:
* Deprecate at least one of the documentation locations in order to
reduce developer effort required to maintain it. I suspect
http://trac.openlayers.org/wiki/Documentation should be deprecated, or
at least we should remove the link to it from http://openlayers.org
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev mailing list
