[OpenLayers-Dev] KML / OWS Context support in OpenLayers
Pat Cappelaere
pat at cappelaere.com
Thu Aug 2 08:23:19 EDT 2007
It was just pointed out to being an issue to address.
I hope that everyone will have a chance to jump in and shake that tree :)
Can we use CSS?
Pat G. Cappelaere
Vightel Corporation
www.vightel.com
Cell: 410.340.4868
Bus: 443.283.0369
Fax: 443.283.0370
> From: Sebastian Schmitz <sebastian.schmitz at wheregroup.com>
> Date: Thu, 02 Aug 2007 14:19:27 +0200
> To: Pat Cappelaere <pat at cappelaere.com>
> Cc: Tim Schaub <tschaub at openplans.org>, openlayers <dev at openlayers.org>
> Subject: Re: [OpenLayers-Dev] KML / OWS Context support in OpenLayers
> Hi
> What happened to the issue at the Kick-Off meeting? Harmonization hints
> should be one outcome of OWS-5, I believe.
> Cheers
> Sebastian
> Pat Cappelaere schrieb:
>> I think that you have put your finger right on the problem.
>> [BTW, I raised the same issue at the OGC kickoff meeting]
>> Styling is an ongoing huge issue (and has been for years) and might have to
>> be completely re-thought.
>> Pat G. Cappelaere
>> Vightel Corporation
>> www.vightel.com
>> Cell: 410.340.4868
>> Bus: 443.283.0369
>> Fax: 443.283.0370
>>> Date: Thu, 02 Aug 2007 10:08:35 +0200
>>> To: Tim Schaub <tschaub at openplans.org>
>>> Cc: openlayers <dev at openlayers.org>
>>> Hi,
>>> as stated in another thread, Mapbender wants to push KML (render and
>>> style) support in OpenLayers in order to integrate OpenLayers as map
>>> tool lib. Mapbender and TOPP should join forces. How?
>>> To my mind, step 1 would be to support KML 2 geometries and styling in
>>> such a client, step2 would be to write that clients state into an
>>> KML/OWS Context document, right?
>>> How would you use an integrated KML / OWS Context client without being
>>> able to render and style KML features?
>>> Cheers
>>> Sebastian
>>> Tim Schaub schrieb:
>>>> Hello-
>>>> The Open Planning Project has received OGC funding to work on an
>>>> integrated KML/OWS Context implementation. Our proposal was based on
>>>> building this support into OpenLayers. I will be working on this over
>>>> the next few months - and look forward to collaborating with other folks
>>>> interested in the same.
>>>> Note that much of this work is about supporting a yet-to-be determined
>>>> specification that integrates KML and OWS Context (which is different
>>>> than getting support for KML 2, for example).
>>>> Tim
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> WhereGroup
>>> GmbH & Co. KG
>>> Siemensstr. 8
>>> D-53121 Bonn
>>> Amtsgericht Bonn, HRA 6788
>>> Fon: +49 (0)228 / 90 90 38 - 24
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> mailto:sebastian.schmitz at wheregroup.com
>>> http://www.wheregroup.com
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Arnulf Christl, Olaf Knopp, Peter Stamm
>>> Dev mailing list
> WhereGroup
> GmbH & Co. KG
> Siemensstr. 8
> D-53121 Bonn
> Komplementärin:
> vertreten durch:
More information about the Dev
