[OpenLayers-Dev] KML / OWS Context support in OpenLayers
Sebastian Schmitz
sebastian.schmitz at wheregroup.com
Thu Aug 2 08:19:27 EDT 2007
Hi
What happened to the issue at the Kick-Off meeting? Harmonization hints
should be one outcome of OWS-5, I believe.
Cheers
Sebastian
Pat Cappelaere schrieb:
> I think that you have put your finger right on the problem.
> [BTW, I raised the same issue at the OGC kickoff meeting]
> Styling is an ongoing huge issue (and has been for years) and might have to
> be completely re-thought.
> Pat G. Cappelaere
> Vightel Corporation
> www.vightel.com
> Cell: 410.340.4868
> Bus: 443.283.0369
> Fax: 443.283.0370
>> From: Sebastian Schmitz <sebastian.schmitz at wheregroup.com>
>> Date: Thu, 02 Aug 2007 10:08:35 +0200
>> To: Tim Schaub <tschaub at openplans.org>
>> Cc: openlayers <dev at openlayers.org>
>> Subject: Re: [OpenLayers-Dev] KML / OWS Context support in OpenLayers
>> Hi,
>> as stated in another thread, Mapbender wants to push KML (render and
>> style) support in OpenLayers in order to integrate OpenLayers as map
>> tool lib. Mapbender and TOPP should join forces. How?
>> To my mind, step 1 would be to support KML 2 geometries and styling in
>> such a client, step2 would be to write that clients state into an
>> KML/OWS Context document, right?
>> How would you use an integrated KML / OWS Context client without being
>> able to render and style KML features?
>> Cheers
>> Sebastian
>> Tim Schaub schrieb:
>>> Hello-
>>> The Open Planning Project has received OGC funding to work on an
>>> integrated KML/OWS Context implementation. Our proposal was based on
>>> building this support into OpenLayers. I will be working on this over
>>> the next few months - and look forward to collaborating with other folks
>>> interested in the same.
>>> Note that much of this work is about supporting a yet-to-be determined
>>> specification that integrates KML and OWS Context (which is different
>>> than getting support for KML 2, for example).
>>> Tim
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> WhereGroup
>> GmbH & Co. KG
>> Siemensstr. 8
>> D-53121 Bonn
>> Amtsgericht Bonn, HRA 6788
>> Fon: +49 (0)228 / 90 90 38 - 24
>> Fax: +49 (0)228 / 90 90 38 - 11
>> mailto:sebastian.schmitz at wheregroup.com
>> http://www.wheregroup.com
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
>> Dev mailing list
WhereGroup
GmbH & Co. KG
Siemensstr. 8
D-53121 Bonn
Komplementärin:
vertreten durch:
More information about the Dev
