[OpenLayers-Dev] KML / OWS Context support in OpenLayers
Pat Cappelaere
pat at cappelaere.com
Thu Aug 2 08:05:08 EDT 2007
I think that you have put your finger right on the problem.
[BTW, I raised the same issue at the OGC kickoff meeting]
Styling is an ongoing huge issue (and has been for years) and might have to
be completely re-thought.
Pat G. Cappelaere
Vightel Corporation
www.vightel.com
Cell: 410.340.4868
Bus: 443.283.0369
Fax: 443.283.0370
> From: Sebastian Schmitz <sebastian.schmitz at wheregroup.com>
> Date: Thu, 02 Aug 2007 10:08:35 +0200
> To: Tim Schaub <tschaub at openplans.org>
> Cc: openlayers <dev at openlayers.org>
> Subject: Re: [OpenLayers-Dev] KML / OWS Context support in OpenLayers
> Hi,
> as stated in another thread, Mapbender wants to push KML (render and
> style) support in OpenLayers in order to integrate OpenLayers as map
> tool lib. Mapbender and TOPP should join forces. How?
> To my mind, step 1 would be to support KML 2 geometries and styling in
> such a client, step2 would be to write that clients state into an
> KML/OWS Context document, right?
> How would you use an integrated KML / OWS Context client without being
> able to render and style KML features?
> Cheers
> Sebastian
> Tim Schaub schrieb:
>> Hello-
>> The Open Planning Project has received OGC funding to work on an
>> integrated KML/OWS Context implementation. Our proposal was based on
>> building this support into OpenLayers. I will be working on this over
>> the next few months - and look forward to collaborating with other folks
>> interested in the same.
>> Note that much of this work is about supporting a yet-to-be determined
>> specification that integrates KML and OWS Context (which is different
>> than getting support for KML 2, for example).
>> Tim
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> WhereGroup
> GmbH & Co. KG
> Siemensstr. 8
> D-53121 Bonn
> Amtsgericht Bonn, HRA 6788
> Fon: +49 (0)228 / 90 90 38 - 24
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:sebastian.schmitz at wheregroup.com
> http://www.wheregroup.com
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Dev mailing list
More information about the Dev
