[OpenLayers-Dev] Patch: fix argument handling in Function.bind()
Pierre GIRAUD bluecarto at gmail.com
Fri Aug 3 03:05:40 EDT 2007
It seems like this proposed patch has never been proposed in the track.
I will right now.
Best,
Pierre
On 5/18/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Fri, May 18, 2007 at 02:38:04PM +0100, Andy Armstrong wrote:
> > On 18 May 2007, at 14:27, Christopher Schmidt wrote:
> > >The place was right, the mechanism was wrong :) I couldn't turn the
> > >text
> > >in the body of the email into a patch. If you could create a ticket
> > >and
> > >submit a patch following the directions on
> > >http://trac.openlayers.org/wiki/FilingTickets , I'll mark it for
> > >2.4 and
> > >make sure it gets reviewed.
> > Cool, sorry about that. I should have checked. I've just applied for
> > a password.
> Yep, your account is set up now.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
