[OpenLayers-Dev] playing nicely with prototype Event
Erik Uzureau
erik.uzureau at metacarta.com
Fri Aug 3 10:57:25 EDT 2007
http://trac.openlayers.org/ticket/880
On 7/26/07, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> thanks for the quick analysis, chris.
> I'll make the ticket and patch.
> Erik
> On 7/26/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > On Thu, Jul 26, 2007 at 02:27:09PM -0500, Erik Uzureau wrote:
> > > ooooo.... this is a good find, paul.
> > The reason for doing this was, at the time, to provide support for
> > 'Event.stop()', which was regularly used by users at the application
> > level.
> > It is likely that we can just stop doing this -- if you have an existing
> > 'Event', it probably has a 'stop', and if it doesn't, well, you probably
> > shouldn't be expecting OpenLayers to tack it on to your existing event
> > object anyway.
> > I'd say this can be filed as a bug in 2.5.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
More information about the Dev
