[OpenLayers-Dev] Open Location Services & Openlayers
Andrew Hughes ahhughes at gmail.com
Mon Aug 6 20:25:30 EDT 2007
Hi Gianni,
Very Good!
FYI: I no longer work for TerraPages... but they have a Java based OLS API
that they plan to open source. I was leading this while I worked there.
See: http://terrapages.net/opengis-api/
It is the complete OLS spec v1.1 which is most useful for implementing OLS
spec java services and java clients.
Like this: https://terrapages.net/opengis-xls/
If you want to chase this up, I would recommend you talk to Cameron Shorter.
--AH
On 8/7/07, Gianni.Barrotta at corenet.it <Gianni.Barrotta at corenet.it> wrote:
> Hi,
> i'm successfully using openlayers in a couple of projects; one of them is
> an implementation of the standardOGC Open LS (OpenGIS Location Service, used
> by google too in google maps).
> Here is an example of the use of route objects to search directions for an
> Italian region called Sardinia:
> http://coreweb2.corenet.it/sandbox/resources/html/route.html
> Directions are of course in Italian Language; it's still a "work in
> progress"...
> I'd love to share this objects with openlayers community, even as related
> project or committing our objects to the repository.
> The idea would be to give to the openlayers community a support to add
> directions on their maps; we've to decide if this might be a goog or bad
> idea.
> P.S.
> Here you can find a description of the standard:
> http://www.opengeospatial.org/standards/olscore
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070807/9e6ed810/attachment.html
More information about the Dev mailing list
