[OpenLayers-Dev] change default size of the overview map
Frédéric Junod
frederic.junod at camptocamp.com
Thu Dec 6 02:55:10 EST 2007
Valentina,
Is the image layer correctly displayed on the map ?
Does is works if you don't set a custom size for your overview map ?
I never use the Image Layer but the 'options' parameter seems to be wrong,
try with:
var panorama = new OpenLayers.Layer.Image(myImage.name,
myImage.src,
panorama_bounds,
panorama_size)
Also check your parameters type:
myImage.name : String
myImage.src: String
panorama_bounds: OpenLayers.Bounds
panorama_size: OpenLayers.Size
see also: http://dev.openlayers.org/apidocs/files/OpenLayers/Layer/Image-js.html
and: http://www.openlayers.org/dev/examples/image-layer.html
Regards,
fredj
PS: please answer to the dev at openlayers.org mailing list, not to my personal
address
Le Wed, 5 Dec 2007 17:10:06 +0000,
"Val Cartei" <val.cartei at gmail.com> a écrit :
> Thanks, I've updated it to:
> var options = {size: new OpenLayers.Size(newWidth, newHeight)};
> map.addControl(new OpenLayers.Control.OverviewMap(options));
> but still it gives me the blue background.
> Could this have something to do with the fact that the image is added on the
> map as a Layers? Like:
> myImage.name,
> myImage.src,
> panorama_bounds,panorama_size,options);
> map.addLayers([panorama]);
> Best,
> Valentina Cartei
> UK Tel. +44 (0)796 6882820
Frédéric Junod
Camptocamp SA
More information about the Dev
