[OpenLayers-Dev] Feature.Vector.atPoint() and Geometry.intersects()
Attila Csipa
plists at prometheus.org.yu
Tue Dec 11 18:30:47 EST 2007
Hi, I was looking at the ticket mentioned below, are the tests from GEOES
mentioned by Chris Schmit committed somewhere (I can't seem to find them in
the tests dir) ? I worked on JTS on similar things a while back and as I need
this functionality for one of my ongoing projects, I actually might be of
help, just need to get in focus where things are. I did not check on
OpenLayers in quite some time but it seemed a good fit for a task so I
checked out the latest stuff and was surprised how much it has progressed in
the last year and a half.
On Monday 10 December 2007 13:42:10 Pierre GIRAUD wrote:
> You're right, the atPoint method intended behavior is to check whether
> a point in contained into a geometry bounding box. This was
> implemented a while ago as an simple way to simulate event handling in
> some cases, though it's far away from being perfect.
> About 2 months ago, Tim Schaub proposed a real intersection method
> support [1]. It's still in progress and help on this would be much
> appreciated.
> Regards,
> Pierre
> [1] http://trac.openlayers.org/ticket/1072
> On Dec 10, 2007 1:34 PM, Attila Csipa <plists at prometheus.org.yu> wrote:
> > I have a question about this method, the description says "Determins
> > whether the feature intersects with the specified location.", however in
> > my experience this returns true if the given point is in the feature's
> > _bounding box_, not the feature itself. Is this the intended behaviour (a
> > bit of clarification of the description would help in that case), or is
> > this a 'todo' style item for which bbox matching is a quick hack ? I'm
> > using the latest svn release of openlayers. Sorry if this has come up
> > earlier, I joined the list fairly recently and found no reference to this
> > on issue on google. _______________________________________________
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
More information about the Dev
