[OpenLayers-Dev] Point handler issue
Eric Lemoine eric.c2c at gmail.com
Wed Dec 12 10:13:07 EST 2007
On Dec 11, 2007 9:32 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hello
> I have an issue with the point handler. The point handler creates a
> temporary layer to temporarily render points. But if you haven't set
> resolutions/scales/... at map creation time but you rather did it when
> creating the baselayer, the point handler's temporary layer won't have
> correct values for resolutions/scales/... Result is: no point will be
> rendered. I've found no clean way to work around the problem. Do you
> see this as a bug? If so, any suggestion on how to fix it?
I opened a ticket and created a patch for that issue. See
<http://trac.openlayers.org/ticket/1205>.
Thx
Eric
More information about the Dev mailing list
