[OpenLayers-Dev] Adding css elements in javascript not working
pdecker
paulad at rmi.net
Fri Dec 14 07:46:13 EST 2007
Hello Tim,
I have tried your suggestion and I still have the problem. No worries, I
will just modify the css and document it. Thanks for the suggestion.
Tim Schaub wrote:
> Hey-
> pdecker wrote:
>> Hello,
>> I have tried to modify some of the css elements as shown below. The
>> div.olControlMousePosition works, but the OverviewMap elements do not
>> work.
>> If I modify the OpenLayers style.css file itself, the elements work. I
>> am
>> using OpenLayer 2.5. Thanks for any help. -Paula
> Try adding theme: null as an option in your map constructor.
> var map = new OpenLayers.Map("map", {theme: null});
> If this works, please file a ticket reporting that the stylesheet
> detection is flawed (as I already suspect it is).
> Tim
>> <html>
>> <head>
>> <link rel="stylesheet" href="../theme/default/style.css"
>> type="text/css"
>> <style type="text/css">
>> div.olControlMousePosition {
>> background-color: #ffffff;
>> font-size: smaller;
>> font-weight: bold;
>> .olControlOverviewMapContainer {
>> position: absolute;
>> bottom: 40px;
>> right: 0px;
>> .olControlOverviewMapMinimizeButton {
>> right: 0px;
>> bottom: 90px;
>> .olControlOverviewMapMaximizeButton {
>> right: 0px;
>> bottom: 90px;
>> </style>
>> <script src="./lib/OpenLayers.js"></script>
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/Adding-css-elements-in-javascript-not-working-tp14316592p14335043.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
