[OpenLayers-Dev] Adding css elements in javascript not working
pdecker
paulad at rmi.net
Fri Dec 14 07:59:08 EST 2007
Hello Andreas,
I think I am already implementing what you've suggested. Here is my code
below.
<html>
<head>
<link rel="stylesheet" href="../theme/default/style.css" type="text/css"
<style type="text/css">
div.olControlMousePosition {
background-color: #ffffff;
font-size: smaller;
font-weight: bold;
.olControlOverviewMapContainer {
position: absolute;
bottom: 40px;
right: 0px;
.olControlOverviewMapMinimizeButton {
right: 0px;
bottom: 90px;
.olControlOverviewMapMaximizeButton {
right: 0px;
bottom: 90px;
</style>
<script src="./lib/OpenLayers.js"></script>
<script type="text/javascript">
var map, wms;
function init(){
// Build the map.
var options = { maxResolution: maxRes,
numZoomLevels: zoomLevels,
controls:[]
map = new OpenLayers.Map('map', options);
map.addControl(nav); /nav created elsewhere
map.addControl(new OpenLayers.Control.PanZoomBar());
map.addControl(mp); //mp created elsewhere
wms = new OpenLayers.Layer.WMS( "WMS Image",
map.addLayer(wms);
var options2 = {
layers: [wms.clone()],
minRatio: 8,
maxRatio: 32
map.addControl(new OpenLayers.Control.OverviewMap(options2));
map.setCenter(new OpenLayers.LonLat(lon, lat), newZoom);
</script>
Thanks.
Andreas Hocevar-2 wrote:
> Hi,
> Tim Schaub wrote:
>> Hey-
>> pdecker wrote:
>>> I have tried to modify some of the css elements as shown below. The
>>> div.olControlMousePosition works, but the OverviewMap elements do not
>>> work.
>>> If I modify the OpenLayers style.css file itself, the elements work. I
>>> am
>>> using OpenLayer 2.5. Thanks for any help. -Paula
>> Try adding theme: null as an option in your map constructor.
>> var map = new OpenLayers.Map("map", {theme: null});
>> If this works, please file a ticket reporting that the stylesheet
>> detection is flawed (as I already suspect it is).
> We had the same issue with the OverviewMap in Mapbuilder. We solved it
> by adding the stylesheet prior to initializing the OpenLayers map. Don't
> know if this information is helpful for you.
> Regards,
> Andreas.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/Adding-css-elements-in-javascript-not-working-tp14316592p14335422.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
