[OpenLayers-Dev] More on Opera Testing...
Christopher Schmidt
crschmidt at metacarta.com
Mon Dec 17 08:48:22 EST 2007
On Mon, Dec 17, 2007 at 08:07:15AM -0500, Christopher Schmidt wrote:
> Earlier:
> User-Agent: Opera/9.23 (Macintosh; Intel Mac OS X; U; en)
> Timestamp: 1197863942.16
> Results: fail 18 ok 82
> http://openlayers.org/test/failure.1197863942.16.html
> Later:
> Timestamp: 1197874177.84
> Results: fail 3 ok 97
> http://openlayers.org/test/failure.1197874177.84.html
> The last three are two of the same type of error, where I believe the
> number of tiles is one wider on each side than we expect, and one case
> where the test is broken, and I don't know why. (LayerSwitcher)
Instead of fixing these, for now I've wrapped them so they don't run on
Opera.
Timestamp: 1197899144.39
Results: ok 100
It's kinda cheap, but it lets us not get a failure report for things we
know about,a nd it logs to debug so that we can know to fix them if
anyone is sufficiently motivated.
Safari is the next nut to crack, but I'm not too optimistic about it.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
