[OpenLayers-Dev] [Autotest] OpenLayers Test Failure: fail 1 ok 100
Christopher Schmidt crschmidt at metacarta.com
Thu Dec 20 20:53:11 EST 2007
This failure is:
fail Util.removeItem works on more than one element . eq: values differ:
got 1,2,4,5, but expected 1,2,5
I *think* this means that something is bork, but I can't check the
machine at the moment to see if this is just a cache issue. Could
someone in IE run the current tests and see if this failure pops up at
them?
On Thu, Dec 20, 2007 at 03:40:55PM -0500, crschmidt at metacarta.com wrote:
> Results: fail 1 ok 100
> URL: http://openlayers.org/test/failure.1198183255.36.html
> User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30)
> Autotest mailing list
> Autotest at openlayers.org
> http://openlayers.org/cgi-bin/mailman/listinfo/autotest
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
