[OpenLayers-Dev] firefox events problem
Christopher Schmidt
crschmidt at metacarta.com
Thu Dec 20 08:12:47 EST 2007
On Thu, Dec 20, 2007 at 04:07:54PM +0800, li ethan wrote:
> Dear listers!
> I have a problem about trigger event on firefox2.0, Currently I'm
> using openlayers-2.5,and construct a marker like this:
> var marker = new OpenLayers.Marker(lonlat);
> marker1.events.register("mouseover", marker1, function(evt) {
> alert("test");
> Event.stop(evt); });
> markers.addMarker(marker1);
> when I use IE7,there is no problem,I can see the alert window,but when I use
> firefox2.0,it seems like the event never fired,nothing happend on the
> screen.Did anyone encounter the same problem,or it's just my code's
> problem,Am I missing anything about events.Thanks for any kind of help!
Comment #1: "Event.stop()" is old and bad. Use OpenLayers.Event.stop()
if you need to do this.
Now, to your question: I have no exprience that would indicate that this
doesn't work, and believe I've done something similar before. can you
produce a reduced test case that you can share as an HTML file?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
