[OpenLayers-Dev] animated zooming 1.0
John Cole
john.cole at uai.com
Fri Feb 2 12:27:02 EST 2007
Emanual,
Yes, this appears to be the current behavior, see
http://openlayers.org/dev/examples/controls.html
John
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Friday, February 02, 2007 10:23 AM
To: John Cole
Cc: 'Emanuel Sch?tze'; dev at openlayers.org
Subject: Re: [OpenLayers-Dev] animated zooming 1.0
On Fri, Feb 02, 2007 at 10:20:28AM -0600, John Cole wrote:
> Emanual,
> I really like it! The only thing I noticed is that if you drag the
slider
> above or below the zoom bar, the zoom doesn't happen. This makes it hard
to
> use the slider to zoom all the way in or out.
I'm pretty sure this is the behavior in the existing zoom as well. At
least, I can't see any difference in the old behavior and hte new
behavior: can you confirm that this is the existing behavior?
Regards,
Christopher Schmidt
MetaCarta
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.432 / Virus Database: 268.17.19/663 - Release Date: 2/1/2007
2:28 PM
No virus found in this outgoing message.
2:28 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
More information about the Dev
