[OpenLayers-Dev] tile problem
Christopher Schmidt
crschmidt at metacarta.com
Tue Feb 6 11:53:50 EST 2007
On Tue, Feb 06, 2007 at 05:21:15PM +0100, Lars Schrader wrote:
> Hello,
> how can I change OpenLayers to get only one tile?
> I have changed the following things:
> buffer=0 under ../OpenLayers/lib/OpenLayers/Layer/Grid.js
> OpenLayers.Map.TILE_WIDTH = 640; to the viewSize of the map
> OpenLayers.Map.TILE_HEIGHT =320; to the viewSize of the map
> under ../OpenLayers/lib/OpenLayers/Map.js
> Now I get 4 tiles, because the function _initTiles under Grid.js
> don?t create less than 4 tiles.
> Is there any easy way to solve the problem, or is it necessary to
> change the function?
This should be fixed/changed in the latest SVN. Are you using SVN, or an
older release?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
