[OpenLayers-Dev] tile problem
Lars Schrader
lars.schrader at web.de
Wed Feb 7 04:47:31 EST 2007
Am Dienstag, 6. Februar 2007 17:53 schrieben Sie:
> On Tue, Feb 06, 2007 at 05:21:15PM +0100, Lars Schrader wrote:
> > Hello,
> > how can I change OpenLayers to get only one tile?
> > I have changed the following things:
> > buffer=0 under ../OpenLayers/lib/OpenLayers/Layer/Grid.js
> > OpenLayers.Map.TILE_WIDTH = 640; to the viewSize of the map
> > OpenLayers.Map.TILE_HEIGHT =320; to the viewSize of the map
> > under ../OpenLayers/lib/OpenLayers/Map.js
> > Now I get 4 tiles, because the function _initTiles under Grid.js
> > don?t create less than 4 tiles.
> > Is there any easy way to solve the problem, or is it necessary to
> > change the function?
> This should be fixed/changed in the latest SVN. Are you using SVN, or an
> older release?
> Regards,
Hello Christopher,
thanks for your answer. Today I checked out a workspace copy from the svn.
But the problem is the same. Untile yesterday I used OpenLayers-2.3-rc2.
In the OpenLayers directory I find a file called ../Layer/WMS/Untiled.js.
Should these file be used for my problem? How can I
use ../Layer/WMS/Untiled.js instead of ../Layer/WMS.js?
I have inplemeted the WMS-Service by the following code.
function init(){
map = new OpenLayers.Map( $('map') ,
{ controls: [] , 'numZoomLevels':10});
dops = new OpenLayers.Layer.WMS(
"Dops"
, "http://x.x.x.x/cgi-bin/mapserv?"
, {map: '/srv/www/mapserver/xxx/dop/dop.map'
, layers:'Dops', format:'image/jpeg'}
, {maxExtent: new
OpenLayers.Bounds(minx,miny,maxx,maxy)
, maxResolution: 'auto', projection:"EPSG:31467" });
dops.setVisibility(true);
dops.addOptions({isBaseLayer: true});
map.addLayer(dops);
Wrong way?
Greetings, Lars
More information about the Dev
