[OpenLayers-Dev] popups.html example
Les Szklanny lszklanny at where2getit.com
Tue Feb 6 15:12:48 EST 2007
Hi all,
I modified the mousedown() function in the popups.html example to
display a form in the popup, see below.
Why I'm not able to select with a mouse the in the input on Firefox?  It
works as expected on IE 6 and Opera 9.1.
Thx,
Les
        function mousedown(evt) {
            if (popup == null) {
                popup = feature.createPopup();
                popup.setContentHTML("<a
href='http://www.somethingconstructive.net' target='_blank'>click
me</a><form><input type='text' value='test' name='from'/></form>");
                popup.setBackgroundColor("yellow");
                popup.setOpacity(0.7);
                markers.map.addPopup(popup);
            } else {
                markers.map.removePopup(popup);
                popup.destroy();
                popup = null;
            Event.stop(evt);
More information about the Dev mailing list
