[OpenLayers-Dev] tile problem
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Feb 7 05:08:11 EST 2007
Yes WMS Untiled can be used for this purpose, it will only use a single
tile.
Example:
baselayer0 = new OpenLayers.Layer.WMS.Untiled( "Topografische kaart",
"http://intranet.rijkswaterstaat.nl/services/geoservices/basispakket/topografie?",
{layers: 'AAA126,AAA127,AAA134', 'format':'image/jpeg',
'transparent':'true'}, {'numZoomLevels': 7, 'ratio':1, isBaseLayer: true} );
map.addLayer(baselayer0);
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Lars Schrader <lars.schrader at web.de>
Naar: dev at openlayers.org <dev at openlayers.org>
Onderwerp: Re: [OpenLayers-Dev] tile problem
Datum: 07/02/07 07:42
> Am Dienstag, 6. Februar 2007 17:53 schrieben Sie:
> > On Tue, Feb 06, 2007 at 05:21:15PM +0100, Lars Schrader wrote:
> > > Hello,
> > > how can I change OpenLayers to get only one tile?
> > > I have changed the following things:
> > > buffer=0 under ../OpenLayers/lib/OpenLayers/Layer/Grid.js
> > > OpenLayers.Map.TILE_WIDTH = 640; to the viewSize of the map
> > > OpenLayers.Map.TILE_HEIGHT =320; to the viewSize of the map
> > > under ../OpenLayers/lib/OpenLayers/Map.js
> > > Now I get 4 tiles, because the function _initTiles under Grid.js
> > > don?t create less than 4 tiles.
> > > Is there any easy way to solve the problem, or is it necessary
to
> > > change the function?
> > This should be fixed/changed in the latest SVN. Are you using SVN, or
an
> > older release?
> > Regards,
> Hello Christopher,
> thanks for your answer. Today I checked out a workspace copy from the svn.
> But the problem is the same. Untile yesterday I used OpenLayers-2.3-rc2.
> In the OpenLayers directory I find a file called ../Layer/WMS/Untiled.js.
> Should these file be used for my problem? How can I
> use ../Layer/WMS/Untiled.js instead of ../Layer/WMS.js?
> I have inplemeted the WMS-Service by the following code.
> function init(){
> map = new OpenLayers.Map( $('map') ,
> { controls: [] , 'numZoomLevels':10});
> dops = new OpenLayers.Layer.WMS(
> "Dops"
> , "http://x.x.x.x/cgi-bin/mapserv?"
> , {map: '/srv/www/mapserver/xxx/dop/dop.map'
> , layers:'Dops', format:'image/jpeg'}
> , {maxExtent: new
> OpenLayers.Bounds(minx,miny,maxx,maxy)
> , maxResolution: 'auto', projection:"EPSG:31467" });
> dops.setVisibility(true);
> dops.addOptions({isBaseLayer: true});
> map.addLayer(dops);
> Wrong way?
> Greetings, Lars
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
