[OpenLayers-Dev] tile problem
Lars Schrader
lars.schrader at web.de
Wed Feb 7 09:42:06 EST 2007
Hallo Bart,
thanks for your email. That was exactly my problem.
Greetings, Lars
Am Mittwoch, 7. Februar 2007 11:08 schrieb Bart van den Eijnden (OSGIS):
> Yes WMS Untiled can be used for this purpose, it will only use a single
> tile.
> Example:
> baselayer0 = new OpenLayers.Layer.WMS.Untiled( "Topografische kaart",
> "http://intranet.rijkswaterstaat.nl/services/geoservices/basispakket/topogr
>afie?", {layers: 'AAA126,AAA127,AAA134', 'format':'image/jpeg',
> 'transparent':'true'}, {'numZoomLevels': 7, 'ratio':1, isBaseLayer: true}
> map.addLayer(baselayer0);
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Lars Schrader <lars.schrader at web.de>
> Naar: dev at openlayers.org <dev at openlayers.org>
> Onderwerp: Re: [OpenLayers-Dev] tile problem
> Datum: 07/02/07 07:42
> > Am Dienstag, 6. Februar 2007 17:53 schrieben Sie:
> > > On Tue, Feb 06, 2007 at 05:21:15PM +0100, Lars Schrader wrote:
> > > > Hello,
> > > > how can I change OpenLayers to get only one tile?
> > > > I have changed the following things:
> > > > buffer=0 under ../OpenLayers/lib/OpenLayers/Layer/Grid.js
> > > > OpenLayers.Map.TILE_WIDTH = 640; to the viewSize of the map
> > > > OpenLayers.Map.TILE_HEIGHT =320; to the viewSize of the map
> > > > under ../OpenLayers/lib/OpenLayers/Map.js
> > > > Now I get 4 tiles, because the function _initTiles under
> > Grid.js > > don?t create less than 4 tiles.
> > > > Is there any easy way to solve the problem, or is it necessary
> to
> > > > change the function?
> > > This should be fixed/changed in the latest SVN. Are you using SVN,
> > or
> an
> > > older release?
> > > Regards,
> > Hello Christopher,
> > thanks for your answer. Today I checked out a workspace copy from the
> > svn. But the problem is the same. Untile yesterday I used
> > OpenLayers-2.3-rc2. In the OpenLayers directory I find a file called
> > ../Layer/WMS/Untiled.js. Should these file be used for my problem? How
> > can I
> > use ../Layer/WMS/Untiled.js instead of ../Layer/WMS.js?
> > I have inplemeted the WMS-Service by the following code.
> > function init(){
> > map = new OpenLayers.Map( $('map') ,
> > { controls: [] , 'numZoomLevels':10});
> > dops = new OpenLayers.Layer.WMS(
> > "Dops"
> > , "http://x.x.x.x/cgi-bin/mapserv?"
> > , {map: '/srv/www/mapserver/xxx/dop/dop.map'
> > , layers:'Dops', format:'image/jpeg'}
> > , {maxExtent: new
> > OpenLayers.Bounds(minx,miny,maxx,maxy)
> > , maxResolution: 'auto', projection:"EPSG:31467" });
> > dops.setVisibility(true);
> > dops.addOptions({isBaseLayer: true});
> > map.addLayer(dops);
> > Wrong way?
> > Greetings, Lars
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
More information about the Dev
