[OpenLayers-Dev] googleLayer disappears,
not shown again until mousemove stop
Christopher Schmidt
crschmidt at metacarta.com
Fri Feb 16 08:39:05 EST 2007
On Fri, Feb 16, 2007 at 11:15:05AM +0100, Jonas Beck wrote:
> hello,
> i am quite new to this list. experimenting around with OpenLayers (damn
> that's fun), i ran into a problem using a googleLayer.
> the whole googleLayer disappears all tiles at once, nevermind which kind
> of googleLayer (satellite/map/hybrid) i use. it seems to disappear
> around the moment when some new tiles should be loaded. anybody ran into
> that one too? i feel this is quite inconvenient, it just ruins the fun
> when browsing with a googleLayer in my map. im not into google, but it
> would make my work a lot easier , and better looking =).
I've seen this behavior many times. However, I am firmly of the belief
that this misbehavior is outside the realm of OpenLayers: the Google
Layer simply calls 'setCenter' many many times, most likely in a way
that is not designed to be supported by Google.
OpenLayers has an internal 'moveTo' operation on layers that is called
differently when dragging. I expect that Google has a similar function
-- which explains why you don't see the problem on Google Maps
applications -- but without the code being available it's not possible
to check it out.
At some point, I may try to form a small example that doesn't involve
OpenLayers which reproduces this, so I can take it to Google/Google
mailing lists, but it is my expectation at the moment that this problem
is not something that OpenLayers has control over.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
