[OpenLayers-Dev] Patches Need Tests
Cameron Shorter cameron.shorter at gmail.com
Sun Feb 18 14:16:54 EST 2007
Nice,
I believe you have covered all my suggestions.
Christopher Schmidt wrote:
> On Sun, Feb 18, 2007 at 07:07:56AM +1100, Cameron Shorter wrote:
>> Chris,
>> I think that your guidelines should specify that if someone provides a
>> patch, then they should also provide a patch for the tests for that
>> file. It would help if there is a "Writing Unit Tests" at
>> http://trac.openlayers.org/wiki/CodingStandards has some more detail:
>> * Note the JS tool being used for testing.
>> * Point to the tool's documentation explaining how to write tests
>> * Probably write a short howto explaining what is expected from users.
> http://trac.openlayers.org/wiki/CodingStandards now links to
> http://trac.openlayers.org/wiki/WritingUnitTests , which sounds like 1
> and 2 of above. I'd gladly take feedback on what 3. should be :)
>> I'd expect to see writing Unit Tests added as a requirement to "Upload
>> your patch" linked from http://trac.openlayers.org/wiki/HowToContribute
> I've put it in http://trac.openlayers.org/wiki/CreatingPatches which is
> linked from that page.
>> Do you testing tools provide you with a code coverage report?
> I think the answer to this is 'no'. I don't have any clue how you would
> create such a report in the Javascript environment.
> Regards,
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5011
Mob: +61 (0)419 142 254
More information about the Dev mailing list
