[OpenLayers-Dev] Patches Need Tests
Paul Spencer
pspencer at dmsolutions.ca
Sun Feb 18 21:04:56 EST 2007
Chris,
I recommend putting in something about requiring tests to be run
against the major browsers - at least IE 6/7 and FireFox :)
Cheers
Paul
On 18-Feb-07, at 8:42 AM, Christopher Schmidt wrote:
> On Sun, Feb 18, 2007 at 07:07:56AM +1100, Cameron Shorter wrote:
>> Chris,
>> I think that your guidelines should specify that if someone
>> provides a
>> patch, then they should also provide a patch for the tests for that
>> file. It would help if there is a "Writing Unit Tests" at
>> http://trac.openlayers.org/wiki/CodingStandards has some more detail:
>> * Note the JS tool being used for testing.
>> * Point to the tool's documentation explaining how to write tests
>> * Probably write a short howto explaining what is expected from
>> users.
> http://trac.openlayers.org/wiki/CodingStandards now links to
> http://trac.openlayers.org/wiki/WritingUnitTests , which sounds like 1
> and 2 of above. I'd gladly take feedback on what 3. should be :)
>> I'd expect to see writing Unit Tests added as a requirement to
>> "Upload
>> your patch" linked from http://trac.openlayers.org/wiki/
>> HowToContribute
> I've put it in http://trac.openlayers.org/wiki/CreatingPatches
> which is
> linked from that page.
>> Do you testing tools provide you with a code coverage report?
> I think the answer to this is 'no'. I don't have any clue how you
> would
> create such a report in the Javascript environment.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
