[OpenLayers-Dev] Need Help Using Multiple Map Files
Brian Krebs
bkrebs at korterra.com
Fri Jan 19 16:15:08 EST 2007
The mapName parameter is always correct based on the customerid that is
logged in, so there isn't a problem there.
I just noticed that if I delete the folders within the tmp folder:
$szBaseCacheDir = "E:/qa/webapp/kamap/tmp/";
When I log in as customerid2, it creates a customerid1 folder within
that path instead of a customerid2 folder. Even when I remove
customerid1 from the config.php, delete customerid1 folder from tmp and
then bring up the map again, it still creates a customerid1 folder and
map tiles.
Is something getting stuck in memory or what's happening here?
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Friday, January 19, 2007 12:44 PM
To: Brian Krebs
Cc: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] Need Help Using Multiple Map Files
On Fri, Jan 19, 2007 at 12:29:15PM -0600, Brian Krebs wrote:
> I'm attempting to use OpenLayers with two different map files. The
map
> to use is based on the customerid the user logs in with.
> If I log in as customerid1 and open the map, I see the
customerid1.map.
> When someone else logs in as customerid2, they also see the
> customerid1.map. What needs to be done to get the correct map to
> display for each customerid?
I don't think you gave enough context.
initializeMapStart takes a mapName parameter. This parameter defines
what map you'll see out of ka-Map. The computation of that mapName
variable seems to be the code that you need to be looking at. (If you
add "alert(mapName)" as the first line of initializeMapStart, it should
tell you what mapName is actually getting in there.)
If you can figure out why that mapName isn't what you expect, I think
you'll be on your way forward.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
