[OpenLayers-Dev] using overlays with tilecache
Frank Porcelli
fporcelli at taic.net
Sat Jan 20 13:24:00 EST 2007
Chris --
I am using 2.3sv1. I found that the problem was due to not setting
"reproject: false" in my layer definition statement. As soon as I set the
reproject parameter the problem went away.
Good to know for others who run into the same issue.
Thanks,
Frank
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Friday, January 19, 2007 5:41 PM
To: Frank Porcelli
Cc: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] using overlays with tilecache
On Fri, Jan 19, 2007 at 01:47:48PM -0500, Frank Porcelli wrote:
> Dev team -
> I have run into an issue with OpenLayers that I'm hoping someone may have
> experienced and can provide a work around. When using TileCache with
> OpenLayers to display multiple layers of data, I'm noticing that when
> changing zoom levels or panning to a location outside of the initial
extent
> the overlay tiles come back pink. On the initial load, both layers load
fine
> and display no problem. The initial "zoom in" also works fine. However,
when
> panning to another part of the map, using the overview map or pan tool,
> overlay images that are outside the initial extent come back pink. If I
zoom
> out to full exent I also notice that the number of overlay tiles does not
> marry up with the number of basemap tiles. This could partially explain
why
> the pink tiles. Has anyone run into this issue before? This appears to be
a
> bug in OpenLayers. If so, any suggestions on what could be the cause would
> be appreciated.
Frank:
The "Pink Tile Syndrome" has been reported by a variety of users,
usually on data which is not pre-cached. I haven't personally run into
the problem much, but we've recently (2.3/SVN) added functionality to
help reload tiles which suffer pink tile syndrome.
To enable this functionality in OpenLayers 2.3, simply set the variable:
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
or something similar.
Does doing this help you at all?
You might also check your webserver log for evidence of failure -- the
data might be improperly returned, or something similar. If you can find
a failing server, you might be able to reduce the need for reloads.
If this doesn't help you, please reply and we can investigate further.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
