[OpenLayers-Dev] how to put control tools bar in other div
Ludwig Max Brinckmann
ludwigbrinckmann at gmail.com
Mon Jan 22 10:42:05 EST 2007
I recently asked this question before:
This are some of the answers:
>overview = new OpenLayers.Control.OverviewMap({div: $('controls')});
>In case anybody else is searching for the syntax to add the Overview Map
control outside of the viewport, see
>http://trac.openlayers.org/wiki/Control/OverviewMap#Customlayout
<http://trac.openlayers.org/wiki/Control/OverviewMap#Customlayout>
You can also find an example, with a custom layerswitcher to the right of
the map, at http://www.yunnanexplorer.com/mars.html
HTH
Ludwig
On 1/22/07, Jose Feria Martinez < jose.feria at usm.es> wrote:
> Hi,
> I'm using openlayers and my problem is...:
> ¿how can I put the control tools bar in other div diferent from div map?
> thanks.
> José F. Feria Martínez.
> USM ENDECAR S.A.U. - Grupo ALTRAN
> "Parque Empresarial Las Mercedes"
> C\ Campezo 1, Edificio 1, Planta 1ª
> C.P.: 28 022
> Tfno.: 91 787 24 23
> Fax.: 91 787 24 01
> USM Endecar : <http://www.usm.es>
> Grupo ALTRAN: <http://www.altran.com>
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070122/1f532618/attachment.html
More information about the Dev
