[OpenLayers-Dev] how to put control tools bar in other div
Ludwig Max Brinckmann
ludwigbrinckmann at gmail.com
Mon Jan 22 14:04:45 EST 2007
Thanks, yes of course it can be added to the wiki, although it means I will
have to make sure it stays in a working condition ;-).
I am not sure if the controls were really intuitively understandable:
- dragging on the red slider will turn a layer on (with settings in the
middle controlling the opacity)
- clicking and dragging a layer up and down will change its order in
z-stacking
- the tick box flickers a layer (not very intuitive, this has to go
somewhere else)
Ludwig
On 1/22/07, Erik Uzureau <euzuro at gmail.com> wrote:
> Wow! this is a sweet map, ludwig!
> Can we include a link to this on
> http://trac.openlayers.org/wiki/Gallery
> Thanks,
> Erik
> On 1/22/07, Ludwig Max Brinckmann <ludwigbrinckmann at gmail.com> wrote:
> > I recently asked this question before:
> > This are some of the answers:
> > >overview = new OpenLayers.Control.OverviewMap({div: $('controls')});
> > >In case anybody else is searching for the syntax to add the Overview
> Map
> > control outside of the viewport, see
> > >http://trac.openlayers.org/wiki/Control/OverviewMap#Customlayout
> > You can also find an example, with a custom layerswitcher to the right
> of
> > the map, at http://www.yunnanexplorer.com/mars.html
> > HTH
> > Ludwig
> > On 1/22/07, Jose Feria Martinez < jose.feria at usm.es> wrote:
> > > Hi,
> > > I'm using openlayers and my problem is...:
> > > ¿how can I put the control tools bar in other div diferent from div
> map?
> > > thanks.
> > > José F. Feria Martínez.
> > > USM ENDECAR S.A.U. - Grupo ALTRAN
> > > "Parque Empresarial Las Mercedes"
> > > C\ Campezo 1, Edificio 1, Planta 1ª
> > > C.P.: 28 022
> > > Tfno.: 91 787 24 23
> > > Fax.: 91 787 24 01
> > > USM Endecar : <http://www.usm.es>
> > > Grupo ALTRAN: < http://www.altran.com>
> > > _______________________________________________
> > > Dev mailing list
> > > Dev at openlayers.org
> > > http://openlayers.org/mailman/listinfo/dev
> > Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070122/f859737c/attachment.html
More information about the Dev
