[OpenLayers-Dev] how to put control tools bar in other div
Erik Uzureau
euzuro at gmail.com
Mon Jan 22 15:08:23 EST 2007
Thanks Ludwig, I've added your mars explorer to the list.
The layerswitcher control you've built is amazing!
Erik
On 1/22/07, Ludwig Max Brinckmann <ludwigbrinckmann at gmail.com> wrote:
> Thanks, yes of course it can be added to the wiki, although it means I will
> have to make sure it stays in a working condition ;-).
> I am not sure if the controls were really intuitively understandable:
> - dragging on the red slider will turn a layer on (with settings in the
> middle controlling the opacity)
> - clicking and dragging a layer up and down will change its order in
> z-stacking
> - the tick box flickers a layer (not very intuitive, this has to go
> somewhere else)
> Ludwig
> On 1/22/07, Erik Uzureau <euzuro at gmail.com> wrote:
> > Wow! this is a sweet map, ludwig!
> > Can we include a link to this on
> > http://trac.openlayers.org/wiki/Gallery
> > Thanks,
> > Erik
> > On 1/22/07, Ludwig Max Brinckmann < ludwigbrinckmann at gmail.com> wrote:
> > > I recently asked this question before:
> > > This are some of the answers:
> > > >overview = new OpenLayers.Control.OverviewMap ({div: $('controls')});
> > > >In case anybody else is searching for the syntax to add the Overview
> Map
> > > control outside of the viewport, see
> http://trac.openlayers.org/wiki/Control/OverviewMap#Customlayout
> > > You can also find an example, with a custom layerswitcher to the right
> of
> > > the map, at http://www.yunnanexplorer.com/mars.html
> > > HTH
> > > Ludwig
> > > On 1/22/07, Jose Feria Martinez < jose.feria at usm.es> wrote:
> > > > Hi,
> > > > I'm using openlayers and my problem is...:
> > > > ¿how can I put the control tools bar in other div diferent from div
> map?
> > > > thanks.
> > > > José F. Feria Martínez.
> > > > USM ENDECAR S.A.U. - Grupo ALTRAN
> > > > "Parque Empresarial Las Mercedes"
> > > > C\ Campezo 1, Edificio 1, Planta 1ª
> > > > C.P.: 28 022
> > > > Tfno.: 91 787 24 23
> > > > Fax.: 91 787 24 01
> > > > USM Endecar : <http://www.usm.es>
> > > > Grupo ALTRAN: < http://www.altran.com>
> > > > _______________________________________________
> > > > Dev mailing list
> > > > Dev at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/dev
> > > Dev mailing list
More information about the Dev
