[OpenLayers-Dev] Fwd: [OpenLayers-Users] [PATCH RESEND] TileCache documentation patch [Was: openlayers and tilecache]
Eric Lemoine eric.lemoine at gmail.com
Fri Jan 26 05:20:23 EST 2007
Oops, I forgot to CC: dev.
---------- Forwarded message ----------
Date: Jan 26, 2007 11:18 AM
Subject: [OpenLayers-Users] [PATCH RESEND] TileCache documentation
To: Erik Uzureau <euzuro at gmail.com>
Cc: users at openlayers.org
Hello!
I haven't received any comments regarding my TileCache documentation
patch. I'm resending it here CC:'ing dev at openlayers.org. Could you
please consider it?
Thanks,
Eric
I'm resending my TileCache documentation patch as I haven't received
any comments
On 1/18/07, Eric Lemoine <eric.lemoine at gmail.com> wrote:
> Hi Erik and Christopher,
> On 1/17/07, Erik Uzureau <euzuro at gmail.com> wrote:
> > Hi Eric, I added your question to the OpenLayers FAQ here [1]
> > Is  this all the information one would need to know or should the answer
> > be more complete?
> I'd say it's ok not to give details and point the user to the HTML example.
> However, the directives provided in the README file don't suffice for
> the user to be able to run the HTML example. Indeed, the TileCache
> code must be extracted in a web directory, not only in a directory
> that can run CGI (or mod_python) scripts.
> Also, index.html only works if TileCache was set up under CGI, and
> doesn't work if TileCache was set up under mod_python.
> Attached to this email is a patch to README reflecting the suggested
> doc changes.
> Patch also provided inline:
> --- README.old  2007-01-18 15:14:19.000000000 +0100
> +++ README      2007-01-18 15:13:55.000000000 +0100
> @@ -33,10 +33,19 @@
>  To set up a TileCache under CGI
> - * Extract the code to some location which can run CGI scripts.
> + * Extract the code to some web directory (e.g. in /var/www).
>   * Edit tilecache.cfg to point the DiskCache to the location you wish
>     to cache tiles, and the layers to point to the map file or WMS
>     server you wish to cache
> + * Permit CGI execution in the TileCache directory.
> +   For example, if TileCache is to be run with Apache, the
> +   following must be added in your Apache configuration:
> +     <Directory /var/www/tilecache>
> +         AddHandler cgi-script .cgi
> +         Options +ExecCGI
> +     </Directory>
> +   where /var/www/tilecache is the directory resulting from
> +   the code extraction.
>   * Visit:
>     http://example.com/yourdir/tilecache.cgi?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-180,-90,0,90&WIDTH=256&HEIGHT=256
> @@ -48,8 +57,7 @@
>  To set up a TileCache under mod_python
> - * Extract the code to some location under which you can run
> -   mod_python scripts.
> + * Extract the code to some web directory (e.g. /var/www).
> @@ -58,11 +66,13 @@
>         PythonHandler TileCache.Service
>         PythonOption TileCacheConfig /path/to/tilecache.cfg
>     An example might look like:
> -     <Directory /var/www/wms-c/>
> +     <Directory /var/www/tilecache/>
>           AddHandler python-program .py
> -         PythonOption TileCacheConfig /path/to/tilecache.cfg
> +         PythonOption TileCacheConfig /var/www/tilecache/tilecache.cfg
>       </Directory>
>   * Visit one of the URLs described above, replacing tilecache.cgi with
>     tilecache.py
>   * If you see a tile you have set up your configuration correctly. Congrats!
> @@ -112,4 +122,18 @@
>    url -- URL to use when requesting images from a remote WMS server. Required
>           for WMSLayer.
> +OpenLayers with TileCache
> +To run OpenLayers with TileCache the URL passed to the OpenLayers.Layer.WMS
> +constructor must point to the TileCache script, i.e. tilecache.cgi or
> +tilecache.py. As an example see the index.html file included in the TileCache
> +distribution.
> +Note: index.html assumes TileCache is set up under CGI (see above). If you set
> +up TileCache under mod_python you'd need to slighly modify index.html: the URL
> +passed to the OpenLayers.Layer.WMS constructor must point to the mod_python
> +script as opposed to the CGI script, so replace tilecache.cgi with
> +tilecache.py.
> Eric
Eric
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
Eric
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070126/24d709bc/README-patch.obj
More information about the Dev mailing list
