[OpenLayers-Dev] Formatting degrees in MousePosition
Lance Dyas lancelot at inetnebr.com
Mon Jan 29 09:30:29 EST 2007
Fairly simple code... makes it more glossy/finished seeming.
formatCoords: function (base) {
            var t, t2;
           var degrees = Math.floor(base);
            var minutes = Math.floor(t = ( base - degrees ) * 60);
           var seconds = Math.floor(t2 = ( t - minutes ) * 6000);
            seconds = seconds / 100.00;
            return ("" + degrees + "\u00B0 " + minutes + "\u0027 " +
seconds + "\u0022" );
AND
    if (this.map.units == "degrees") {
          newHtml =  this.formatCoords(lonLat.lon)  + this.separator +
this.formatCoords(lonLat.lat);
    else {
         var digits = parseInt(this.numdigits);
             newHtml =
            this.prefix +
            lonLat.lon.toFixed(digits) +
            this.separator +
            lonLat.lat.toFixed(digits) +
            this.suffix;
More information about the Dev mailing list
