[OpenLayers-Dev] Integrating Google Maps and Mapserver
Bradley Mclain
bradleym06 at gmail.com
Mon Jul 2 01:51:29 EDT 2007
Also just thought that I'd mention that my Mapserver is not properly set up
as a WMS and it will be quite difficult to do so so I'd rather use the cgi
mode of Mapserver. However when looking at the Mapserver examples I failed
to see anything at all which resembled this. It calls "
http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
"cgi-bin/mapserv?map=" somewhere.
Cheers
Brad
On 7/2/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> Ok I made some progress but I have hit a few roadblocks. At the moment my
> code successfully displays the google map, hybrid and satelite images.
> However only if it is opened from its current location if I try to open it
> on my server, i get an error displaying that my google maps api does not
> correspond. However even when i registered a new one for
> http://192.168.1.130 (my server address) the page simply displays as plain
> white.
> My second problem is getting mapserver to display. Below is my current
> attempt to get it to work. What am supposed to call the mapfile?, or direct
> it to the url of the working map?
> <html>
> <head>
> <script src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>"
> type="text/javascript"></script>
> <script src="../lib/OpenLayers.js" type="text/javascript"></script>
> </head>
> <body>
> <h4>Debortoli Wines OpenLayers Test</h4>
> <div style="width:100%; height:80%" id="map"></div>
> <script defer="defer" type="text/javascript">
> OpenLayers.ProxyHost="/proxy/?url=";
> var map = new OpenLayers.Map( 'map', {controls: [new
> OpenLayers.Control.PanZoomBar()]} );
> //Adding Controls
> map.addControl(new OpenLayers.Control.MouseToolbar());
> map.addControl(new OpenLayers.Control.MousePosition ());
> map.addControl(new OpenLayers.Control.Permalink());
> var layer_switcher = new OpenLayers.Control.LayerSwitcher();
> map.addControl(layer_switcher);
> layer_switcher.maximizeControl();
> //Adding Layers
> var google = new OpenLayers.Layer.Google("Google");
> var googles = new OpenLayers.Layer.Google("Google Satellite", {
> 'type': G_SATELLITE_MAP });
> var googleh = new OpenLayers.Layer.Google("Google Hybrid", { 'type':
> G_HYBRID_MAP });
> var mapserv = new Openlayers.Layer.HTTPRequest("Debortoli Mapserver",
> "http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&layers=dbap&mode=browse
> map.addLayers([google, googles, googleh, mapserv]);
> map.setCenter(new OpenLayers.LonLat(135,-28), 4);
> </script>
> </body>
> </html>
> > Cool I'll look into that and get back to you with my progress. Currently
> > having issues getting my google map to display, its just shows up as white.
> > I registered a new key and everything.
> > On 7/2/07, Anselm Hook <anselm at gmail.com> wrote:
> > > Oh, actually that example is not perfectly clear; it doesn't expressly
> > > illuminate that you can choose to leave more than one layer on at a
> > > time.... in any case you can do so.
> > > - a
> > > On 7/1/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > http://openlayers.org/gallery/multiple.html
> > > > On 7/1/07, Bradley Mclain < bradleym06 at gmail.com> wrote:
> > > > > Hey
> > > > > What I am looking to do is to integrate Google Maps with a custom
> > > > > map which is being served from Mapserver. I currently have Mapserver working
> > > > > and serving the correct layers. I just have a few questions about this which
> > > > > I am hoping you can answer.
> > > > > Is it possible to use openlayers to integrate the two?
> > > > > If not, are there any other possible programs which I can use to
> > > > > do this?
> > > > > If so, how do I go about this?
> > > > > Cheers
> > > > > Brad
> > > > > _______________________________________________
> > > > > Dev mailing list
> > > > > Dev at openlayers.org
> > > > > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070702/40c950c1/attachment.html
More information about the Dev
