[OpenLayers-Dev] Integrating Google Maps and Mapserver
Ludwig M Brinckmann
ludwigbrinckmann at gmail.com
Mon Jul 2 04:23:14 EDT 2007
On 02/07/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> Also just thought that I'd mention that my Mapserver is not properly set
> up as a WMS and it will be quite difficult to do so so I'd rather use the
> cgi mode of Mapserver. However when looking at the Mapserver examples I
> failed to see anything at all which resembled this. It calls "
> http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
> "cgi-bin/mapserv?map=" somewhere.
The form the URL looks at the beginning is irrelevant for a servers
compliance with the WMS protocol.
There are many -- reasonably well documented -- ways how the
'cgi-bin/mapserv?/map=' can be hidden. See
http://mapserver.gis.umn.edu/docs/howto/cgi-wrapper-script.
But the first thing to test is if your server works at all -- outside the
OpenLayers client. Run something like
http://www.yunnanexplorer.com/cgi-bin/wms?request=getmap&service=wms&version=1.1&layers=earthquakes
in your browser (substituting your layer names and your URL). If your server
works, you should get a map image, if not an XML error message.
Once this is working, you can add your server to your OpenLayers client as a
WMS server (the HttpRequest bit will not work).
HTH
Ludwig
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070702/48e59173/attachment.html
More information about the Dev
