[OpenLayers-Dev] Integrating Google Maps and Mapserver
Bradley Mclain
bradleym06 at gmail.com
Mon Jul 2 20:15:46 EDT 2007
Ok after some mucking around i managed to get the request to return a file
save message, however it returns this even when i use getmap not just
getcapabilities. Any idea why it is doing this?
The message is something like you have chosen to open mapserv which is an:
application/vnd.ogc.se_xml
my request was
http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&service=wms&version=1.1.1&request=getmap&layers=dbap
Also i am having trouble getting the wrapper to work but this is not my
priority yet.
On 7/2/07, Ludwig M Brinckmann <ludwigbrinckmann at gmail.com> wrote:
> On 02/07/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> > Also just thought that I'd mention that my Mapserver is not properly set
> > up as a WMS and it will be quite difficult to do so so I'd rather use the
> > cgi mode of Mapserver. However when looking at the Mapserver examples I
> > failed to see anything at all which resembled this. It calls "
> > http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
> > "cgi-bin/mapserv?map=" somewhere.
> The form the URL looks at the beginning is irrelevant for a servers
> compliance with the WMS protocol.
> There are many -- reasonably well documented -- ways how the
> 'cgi-bin/mapserv?/map=' can be hidden. See
> http://mapserver.gis.umn.edu/docs/howto/cgi-wrapper-script.
> But the first thing to test is if your server works at all -- outside the
> OpenLayers client. Run something like
> http://www.yunnanexplorer.com/cgi-bin/wms?request=getmap&service=wms&version=1.1&layers=earthquakes
> in your browser (substituting your layer names and your URL). If your
> server works, you should get a map image, if not an XML error message.
> Once this is working, you can add your server to your OpenLayers client as
> a WMS server (the HttpRequest bit will not work).
> HTH
> Ludwig
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070703/443ea985/attachment.html
More information about the Dev
