[OpenLayers-Dev] Integrating Google Maps and Mapserver
Bradley Mclain
bradleym06 at gmail.com
Mon Jul 2 21:24:22 EDT 2007
Small update, WMS is properly working now I can request it and it returns
the correct layers. the wrapper is not working at all but it can probably
wait till last. I have tried to get openlayers to import the WMS data but it
won't
This is is the code i've used:
var mapservwms = new OpenLayers.Layer.WMS("De Bortoli Mapserver", ['
http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbwwms.map&service=wms&version=1.1&request=getmap&layers=dbwap,bcadbd,hcadbd'])<http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&service=wms&version=1.1.1&request=getmap&layers=dbap>
however it does not work, i just get a blank screen
On 7/3/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> Ok after some mucking around i managed to get the request to return a file
> save message, however it returns this even when i use getmap not just
> getcapabilities. Any idea why it is doing this?
> The message is something like you have chosen to open mapserv which is an:
> application/vnd.ogc.se_xml
> my request was http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&service=wms&version=1.1.1&request=getmap&layers=dbap
> Also i am having trouble getting the wrapper to work but this is not my
> priority yet.
> On 7/2/07, Ludwig M Brinckmann < ludwigbrinckmann at gmail.com> wrote:
> > On 02/07/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> > > Also just thought that I'd mention that my Mapserver is not properly
> > > set up as a WMS and it will be quite difficult to do so so I'd rather use
> > > the cgi mode of Mapserver. However when looking at the Mapserver examples I
> > > failed to see anything at all which resembled this. It calls "
> > > http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
> > > "cgi-bin/mapserv?map=" somewhere.
> > The form the URL looks at the beginning is irrelevant for a servers
> > compliance with the WMS protocol.
> > There are many -- reasonably well documented -- ways how the
> > 'cgi-bin/mapserv?/map=' can be hidden. See
> > http://mapserver.gis.umn.edu/docs/howto/cgi-wrapper-script.
> > But the first thing to test is if your server works at all -- outside
> > the OpenLayers client. Run something like
> > http://www.yunnanexplorer.com/cgi-bin/wms?request=getmap&service=wms&version=1.1&layers=earthquakes
> > in your browser (substituting your layer names and your URL). If your
> > server works, you should get a map image, if not an XML error message.
> > Once this is working, you can add your server to your OpenLayers client
> > as a WMS server (the HttpRequest bit will not work).
> > HTH
> > Ludwig
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070703/acec60f0/attachment.html
More information about the Dev
