[OpenLayers-Dev] Integrating Google Maps and Mapserver
Anselm Hook anselm at gmail.com
Mon Jul 2 21:38:31 EDT 2007
Those are ~probably~ done as a cgi alias?  And / or the actual composition
of specific arguments is handled in javascript?
A while back I put together an example at civicmaps.org - I notice that the
home page is broken at the moment, but the configuration script there may
help.
I must admit setting these things up can be a hassle.
 - a
On 7/1/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> Also just thought that I'd mention that my Mapserver is not properly set
> up as a WMS and it will be quite difficult to do so so I'd rather use the
> cgi mode of Mapserver. However when looking at the Mapserver examples I
> failed to see anything at all which resembled this. It calls "
> http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
> "cgi-bin/mapserv?map=" somewhere.
> Cheers
> Brad
> On 7/2/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> > Ok I made some progress but I have hit a few roadblocks. At the moment
> > my code successfully displays the google map, hybrid and satelite images.
> > However only if it is opened from its current location if I try to open it
> > on my server, i get an error displaying that my google maps api does not
> > correspond. However even when i registered a new one for
> > http://192.168.1.130 (my server address) the page simply displays as
> > plain white.
> > My second problem is getting mapserver to display. Below is my current
> > attempt to get it to work. What am supposed to call the mapfile?, or direct
> > it to the url of the working map?
> > <html>
> > <head>
> >   <script src="http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>"
> > type="text/javascript"></script>
> >     <script src="../lib/OpenLayers.js" type="text/javascript"></script>
> > </head>
> > <body>
> > <h4>Debortoli Wines OpenLayers Test</h4>
> >   <div style="width:100%; height:80%" id="map"></div>
> >   <script defer="defer" type="text/javascript">
> >     OpenLayers.ProxyHost="/proxy/?url=";
> >     var map = new OpenLayers.Map( 'map', {controls: [new
> > OpenLayers.Control.PanZoomBar()]} );
> > //Adding Controls
> >     map.addControl(new OpenLayers.Control.MouseToolbar());
> >     map.addControl(new OpenLayers.Control.MousePosition ());
> >     map.addControl(new OpenLayers.Control.Permalink());
> >     var layer_switcher = new OpenLayers.Control.LayerSwitcher();
> >     map.addControl(layer_switcher);
> >     layer_switcher.maximizeControl();
> > //Adding Layers
> >     var google = new OpenLayers.Layer.Google("Google");
> >     var googles = new OpenLayers.Layer.Google("Google Satellite", {
> > 'type': G_SATELLITE_MAP });
> >     var googleh = new OpenLayers.Layer.Google("Google Hybrid", { 'type':
> > G_HYBRID_MAP });
> >     var mapserv = new Openlayers.Layer.HTTPRequest("Debortoli
> > Mapserver", "http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&layers=dbap&mode=browse
> >     map.addLayers([google, googles, googleh, mapserv]);
> >     map.setCenter(new OpenLayers.LonLat(135,-28), 4);
> >   </script>
> > </body>
> > </html>
> > > Cool I'll look into that and get back to you with my progress.
> > > Currently having issues getting my google map to display, its just shows up
> > > as white. I registered a new key and everything.
> > > On 7/2/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > Oh, actually that example is not perfectly clear; it doesn't
> > > > expressly illuminate that you can choose to leave more than one layer on at
> > > > a time....  in any case you can do so.
> > > >  - a
> > > > On 7/1/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > > http://openlayers.org/gallery/multiple.html
> > > > > On 7/1/07, Bradley Mclain < bradleym06 at gmail.com> wrote:
> > > > > > Hey
> > > > > > What I am looking to do is to integrate Google Maps with a
> > > > > > custom map which is being served from Mapserver. I currently have Mapserver
> > > > > > working and serving the correct layers. I just have a few questions about
> > > > > > this which I am hoping you can answer.
> > > > > > Is it possible to use openlayers to integrate the two?
> > > > > > If not, are there any other possible programs which I can use to
> > > > > > do this?
> > > > > > If so, how do I go about this?
> > > > > > Cheers
> > > > > > Brad
> > > > > > _______________________________________________
> > > > > > Dev mailing list
> > > > > > Dev at openlayers.org
> > > > > > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070702/2f9c23ac/attachment.html
More information about the Dev mailing list
