[OpenLayers-Dev] Integrating Google Maps and Mapserver
Bradley Mclain bradleym06 at gmail.com
Mon Jul 2 21:49:45 EDT 2007
Thanks how do i get to the configuration script?
On 7/3/07, Anselm Hook <anselm at gmail.com> wrote:
> Those are ~probably~ done as a cgi alias?  And / or the actual composition
> of specific arguments is handled in javascript?
> A while back I put together an example at civicmaps.org - I notice that
> the home page is broken at the moment, but the configuration script there
> may help.
> I must admit setting these things up can be a hassle.
>  - a
> On 7/1/07, Bradley Mclain <bradleym06 at gmail.com > wrote:
> > Also just thought that I'd mention that my Mapserver is not properly set
> > up as a WMS and it will be quite difficult to do so so I'd rather use the
> > cgi mode of Mapserver. However when looking at the Mapserver examples I
> > failed to see anything at all which resembled this. It calls "
> > http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
> > "cgi-bin/mapserv?map=" somewhere.
> > Cheers
> > Brad
> > On 7/2/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> > > Ok I made some progress but I have hit a few roadblocks. At the moment
> > > my code successfully displays the google map, hybrid and satelite images.
> > > However only if it is opened from its current location if I try to open it
> > > on my server, i get an error displaying that my google maps api does not
> > > correspond. However even when i registered a new one for
> > > http://192.168.1.130 (my server address) the page simply displays as
> > > plain white.
> > > My second problem is getting mapserver to display. Below is my current
> > > attempt to get it to work. What am supposed to call the mapfile?, or direct
> > > it to the url of the working map?
> > > <html>
> > > <head>
> > >   <script src="http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>"
> > > type="text/javascript"></script>
> > >     <script src="../lib/OpenLayers.js"
> > > </head>
> > > <body>
> > > <h4>Debortoli Wines OpenLayers Test</h4>
> > >   <div style="width:100%; height:80%" id="map"></div>
> > >   <script defer="defer" type="text/javascript">
> > >     OpenLayers.ProxyHost="/proxy/?url=";
> > >     var map = new OpenLayers.Map( 'map', {controls: [new
> > > OpenLayers.Control.PanZoomBar()]} );
> > > //Adding Controls
> > >     map.addControl(new OpenLayers.Control.MouseToolbar());
> > >     map.addControl(new OpenLayers.Control.MousePosition ());
> > >     map.addControl(new OpenLayers.Control.Permalink());
> > >     var layer_switcher = new OpenLayers.Control.LayerSwitcher();
> > >     map.addControl(layer_switcher);
> > >     layer_switcher.maximizeControl();
> > > //Adding Layers
> > >     var google = new OpenLayers.Layer.Google("Google");
> > >     var googles = new OpenLayers.Layer.Google("Google Satellite", {
> > > 'type': G_SATELLITE_MAP });
> > >     var googleh = new OpenLayers.Layer.Google("Google Hybrid", {
> > > 'type': G_HYBRID_MAP });
> > >     var mapserv = new Openlayers.Layer.HTTPRequest("Debortoli
> > > Mapserver", "http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&layers=dbap&mode=browse
> > >     map.addLayers([google, googles, googleh, mapserv]);
> > >     map.setCenter(new OpenLayers.LonLat(135,-28), 4);
> > >   </script>
> > > </body>
> > > </html>
> > > > Cool I'll look into that and get back to you with my progress.
> > > > Currently having issues getting my google map to display, its just shows up
> > > > as white. I registered a new key and everything.
> > > > On 7/2/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > > Oh, actually that example is not perfectly clear; it doesn't
> > > > > expressly illuminate that you can choose to leave more than one layer on at
> > > > > a time....  in any case you can do so.
> > > > >  - a
> > > > > On 7/1/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > > > http://openlayers.org/gallery/multiple.html
> > > > > > On 7/1/07, Bradley Mclain < bradleym06 at gmail.com> wrote:
> > > > > > > Hey
> > > > > > > What I am looking to do is to integrate Google Maps with a
> > > > > > > custom map which is being served from Mapserver. I currently have Mapserver
> > > > > > > working and serving the correct layers. I just have a few questions about
> > > > > > > this which I am hoping you can answer.
> > > > > > > Is it possible to use openlayers to integrate the two?
> > > > > > > If not, are there any other possible programs which I can use
> > > > > > > to do this?
> > > > > > > If so, how do I go about this?
> > > > > > > Cheers
> > > > > > > Brad
> > > > > > > _______________________________________________
> > > > > > > Dev mailing list
> > > > > > > Dev at openlayers.org
> > > > > > > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070703/8ac1003a/attachment.html
More information about the Dev mailing list
